Originally Posted by
lookaught
This statement is contradictory. The added stress caused by the additional distance (and torque) b/c of the spacer causes the bearing life to decrease. If you drove two cars, one with spacers, one without, endlessly around a perfectly smooth oval track, the one with spacers would almost certainly wear out faster unless there is a defect in the heat treatment on the car without the spacers. Therefore, spacers alone CAN wear out the bearings more quickly, regardless of external conditions.
Once you get through the hardened metal on the race and it pits, its game over for bearings.
There is a certain amout of inherent design strength/robustness to Audi wheels bearings. Exactly what this number is, Audi's engineers know. The larger the bearing, often the more stronger it is...
Simply adding spacers "may-or-may not" wear out wheel bearings. Many variables here:
Thickness of spacer- 1mm, 5mm, 10,mm, etc.
Wheel rim size and offset- Some rims "need" spacers...
Tire size, and traction.
road condition
Driving style
Suspension setup.
All these factors effect the life of a wheel bearing.
On my Audi Coupe, I could wear out a set of wheel bearings running SCCA on the weekend. Same exact bearing would last several years of normal street driving. Unless you hit a pot hole... Audi countered this by increasing the bearing size from 76mm to 82mm. My Audi 90 never suffered a single wheel bearing issue in the 13 years I owned it, and it had 18" wheels and 25mm spacers! (OEM wheels were 15")
I'm not gonna tell someone that wheels spacers alone will wear out bearings.
Too many variables, different wheel and tire combo's, etc, etc...
I like absolutegtr's fix:
"Just drive the car the way you want to....if it breaks, fix it"
