Results 1 to 13 of 13
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Exclamation Brake Pads and Sensors: I need some info
    So I knew I was getting pretty low on my pads but didn't know how long until my brake warning light came on as I was driving tonight. In the manual it says that you should stop driving immediately and get it to the dealer as soon as possible.
    Even though I already have new brake rotors from SPP, I haven't gotten the fluid, pads, or SS lines yet and I was wondering if this is super urgent or I can drive on them at all.
    TIA
    EDIT: the new brake rotors have NOT been put on yet, I want to swap the whole system at once. I'm getting Hawk HPS pads but I need to find the best place for SS lines.
    DUH! an Audi
    los angeles, CA
    Re: Brake Pads and Sensors: I need some info
    nate,
    you can drive on them all you want, you just will damage the rotors and you being able to stop might not be as good. Since rotors are new, you would prob waste them once pads get metal to metal....
    Hit up AutoZone or order some pads, should not take more than 2 days to get too you.
    -randy
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Randy,
    I haven't put the new rotors on, I am doing the entire swap with all components at once but my shop is at least 30 miles away. As long as my current setup can hold up for a week and maybe 50 miles I should be good. I don't care if I ruin the pads/rotors, I just don't want to die.
    DUH! an Audi
    los angeles, CA
    shouldnt be too bad, i would take off your wheel to see how bad the pads really are....I would think 50 miles would be safe, but i mean drive carefull...you could always do the install yourself.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Quattro View Post
    -Well I inspected them when I got my BBS's on a week and half ago and they didn't look that bad but I've driven 500 miles since then. I will inspect them tomorrow
    -I don't want to do the install myself because I don't want to try it for the first time on something so important. Maybe next time.
    -I am at 49500 miles on original rotors and I think the second set of pads, did I get a good amount of miles on them?
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    so I just researched all the info on getting Hawk HPS pads and SS lines and it comes out to $325 shipped from ECS tuning, what do you guys think?
    Registered Member Two Rings Laurence@GsG's Avatar
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    Quote Originally Posted by nsmith12 View Post
    As long as its not metal on metal you will be fine. If you let it get to that pt your car will still stop but it may damage your caliper. For sure your rotors will be toast. Ive seen it so bad the the pads weld them self to the rotor which makes its crazy hard to get the caliper off. Just be careful and brake soft to you can get your new pads. Also make sure you don't see any deep groves or you may have to machine your rotor.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    anyone know how much brake fluid we need when we switch?
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Laurence@GsG View Post
    Well I don't think I'm that low on my pads hopefully, is $225 a good price for a shop install of fronts/rears with ss lines and new fluid?
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    You typically have 1-2mm of pad material left once the sensor wire is worn through. But keep in mind that the sensor wire is in only 1 of the 4 front pads and pads don't wear exactly the same. Just drive carefully with light braking and keep your ears open for metal-to-metal contact. Do not drive at that point. You're changing rotors too, so you don't have to worry about the rotor life or grooves.
    3 hours labor @ $75/hr is $225, so I would say that is a decent price. You may be able to find it cheaper, but stick to a shop you trust and pay a little more if you have to.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Well these are the other quotes I got for the same job:
    Euro-wise tuning: $239
    Flow Audi of Greensboro, NC: $690
    GMP Performance: $540
    *Apex Tuning: $225
    Pwrhaus: emailed
    Absolute Automotive: $350
    Black Forest Industries: emailed
    DUH! an Audi
    los angeles, CA
    225 is not that bad, could be done yourself though!
    drive down to la, ill do them for ya =D
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    hahah I'll pass, but I would love to visit LA. As for the brakes, I am already messing around with my DTM kit situation and headlights, not trying to do the brakes too lol
