Results 1 to 14 of 14
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    yes or no bbs wheel question
    will 18x8 cks with a 45 offset clear the calipers?
    yes, no?
    TIA
    the homebrew'd s4
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    Re: yes or no bbs wheel question
    I have the same question but with the audi cos. Et43
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    think about it.
    stock et = 35
    you want to go 43 or 45... this means youre going to add 8mm to your total et.
    no it will not work.
    get some 10 mil spacers and it will work.
    or go hard and get some 15/20 mil spacers and have a total offset of 45-20=25 total et.
    stretch them tires and lower your coils
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    Go with 32 offset
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Stock ET is 45. I vote, maybe.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    my wheels say et45. their stock
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    just checked the spare in my basement, stock et is 45
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    all wheels are made diff.. just because one wheel fits that has a 45et.. doesnt mean another with the same ET will..
    damn people
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by OldYella View Post
    my bad. i been around mk4&3 volkswagens too long.
    if stock is 45 then yes a 45 should fit. but dude is right wheels are made differently so it could touch the caliper.
    if you go a lower et u will be fine
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by ThirdStrike View Post
    Not nessesarily, depends on the inside prfile of the wheels. Not all ET35 wheels are going to fit over the HP2 calipers. With that being said most if not all BBS wheels with a 17"+ diameter and a 5X112 bolt pattern work on the B5 S4.
    Cheers,
    Jim
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    CK is too heavy, skip that wheel please
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by LJH View Post
    Cheers,
    Jim
    yah . ill co-sign.
    but GENERALLY speaking et35 should fit. shit if not slap a 5mm spacer on there. voila
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Quote Originally Posted by b5s4tt View Post
    I bought a set of these a while ago and it was a no go with the stock calipers unless I used spacers. I also corresponded with a member who needed spacers to make it work. You may want to shoot RyansA4 (sp?) [IBG on AW] a PM to confirm as I believe he just mounted CO's on his avant.
    As for the OP, I think you may need spacers to make it work. I checked the BBS Usa website and the CKs they showed for our cars had an offset of 35. That said, I agree with Thirdstrike and think a 5mm spacer should do it.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    you will for sure need spacers because we just had a client in a avant with the same wheels asking why hes BBS did fit. Because it was a no go w/o spacers
