Page 1 of 12 12311 ... LastLast
Results 1 to 40 of 465
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Please help me get in the 11's
    Ko3's are getting noisy and I'm getting bored with them, so going stg3. I would love to go with GT's but thats just not going to happen. So I ordered my PJ Ko4's/oem inlets the other night and now Im trying to figure out what else I need to go 11's. Ive stfa and all that left me with is too many choices of what could be done. All im asking is for a lil help in what to add to the ko4s to be a reliable 11. Do I swap the piggies for DP's or cutouts? Which fueling: Vast, EPL, APR, Marc....? Clutch: Clutchmasters, RS4...? Water meth kit? Car wont be DD but want it to be as reliable. Is there a way I can go reliable to maxed out and back Stg3 as I can with Stg2 giac flashloader? Please help me out so I can get this ish ordered so I can get to TIA
    P.S. I know it has a great deal to do with driving ability, but obviously I at least want the car to have the power available.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Please help me get in the 11's
    ASP w/ WM will get you into 11s easily.
    A guy out here put down 380awhp on 91 with ASP tune and Water/Meth on a DynoDynamics, which is known to be a heartbreaker in terms of giving out low numbers.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Sep 25 2006
    01.5 Laser S4 Avant :: 96 VR6 GTI
    Littleton, CO
    SSP! They have more than one car in the 11s easily.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Quote Originally Posted by chris.mcneal View Post
    Agreed. They actually have proven power. ASP may be awesome, they may suck, but I have never seen an ASP car successfully run at the track. I have also never seen an ASP car run at the track...but that is another story.
    Feb 17 2008
    Ottawa Ont.
    11s is tough on pump gas/full weight/exhaust.
    race gas is a lot easier. but im almost there on 94octane.
    Dec 11 2006
    Boston
    Quote Originally Posted by BastardS4 View Post
    There have been 3 SSP cars (off the top of my head) that have run 11's on pump/full exhaust/full interior. Which is why I say they have proven power.
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    well I do have 93 oct at every pump if that makes things any better + possibly W/M kit
    Sep 25 2006
    Littleton, CO
    And a bit into the 11's too, 11.6 I know for sure... maybe even lower? I am sure some SSP guys will chime in.
    Sep 21 2008
    new braunfels
    I'd start with a different car if 11s is your primary goal... just my .02 which after being taxed by Obama is worth about -.03
    Dec 11 2006
    Boston
    I am an SSP guy.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    marcs tune is good for 11's
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Quote Originally Posted by zmw View Post
    Sure Ill just go buy a Bugatti.....Thanks for your useless .02
    Does SSP have fueling kits or just the tuning?
    And I know Marcs is fast but what psi is his? Not trying to run maxed out all the time.
    Veteran Member Three Rings AielloS4's Avatar
    10' S4
    BOSTON
    Quote Originally Posted by AMC83189 View Post
    fact,
    ran a 11.8 with not the best launching and clutch problems and trapped 124mph. id go with Marcs fueling.
    EUROSPORT-PERFORMANCE
    www.eurosport-performance.com
    Registered Member Two Rings
    Oct 24 2008
    Louisville, Ky
    You will hear that every decent tuner can go into the 11s. It is true. With proper supporting hardware. You'll want VAST piggies, NEW K04s RS4 plumbing including Y pipe, and a modded RS4 airbox, and very solid intercoolers (I strongly recommend ER, if you aren't into cutting your bumper a lot. With W/M, you don't require FMIC), W/M injection, Engine and tranny mounts, snub mount, Drive train Stabilizer, built trans parts, a proper fueling system (I prefer 42 lb injectors and 4 bar FPR for a finer mist), a free flowing cat-back exhaust, and possibly other odds and ends. You will want to ensure that you have solid compression, and excellent leakdown numbers.
    I would also recommend Linear rate springs or pretty stiff progressives, for optimal launching. There's more to it than that, but it's a whole other subject.
    If your engine is running at 100%, you will have a much easier time getting what you are looking for. Simply shoving bigger air and fuel at the problem may make you a sad (and broke) panda.
    I really feel that Mike at VAST performance can get what you are looking for.
    You can also do things like change trans gear ratios to liven things up. If you shift slow, it may be to your advantage to raise gearing and max RPM up, so that you never see 5th or 6th in a 1/4 mile run. 8000 or so RPM is expensive to get to, and you probably couldn't see 23 PSI to it, but being able to ride a longer power band, and hav higher peak HP due to RPM has some serious merit to it. I would run a PSI or so lower, if you want longevity, and raise revs and or gearing.
    Raising engine red line past 7400 on stock valve stuff will probably break things badly.
    Just remember:
    "How fa$$$t do you want to go?"
    More boost is better, until intake temps climb and /or efficiency range is lost.
    More fuel past a point is bad.
    HP=T*R/5252, unless you try to get more HP by raising Rpm past safe. then HP=zero.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Whats the difference between PJ K04's and regular K04's? And where can you get PJ K04's/what makes them different?
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Quote Originally Posted by 4RingsCircus View Post
    Just remember:
    who is this guy??
    Give me a shout tomorrow jeremy.. We will chat.
    Established Member Two Rings Brian@AR's Avatar
    Jan 28 2007
    Portland, OR
    deb38, quick question for you. Are these Ko4 cars running on pump? Anything special about them that they have done to get into the 11's if they are K04 cars? I have seen a couple K04 cars with a GIAC tune run about 11.8 but that was on race gas. How reliable is the tune for a real Daily driver? Just curious. Thanks for your input.
    Quote Originally Posted by deb38 View Post
    Dec 11 2006
    Boston
    Quote Originally Posted by Brian@AR View Post
    Yup pump tunes. One later switched over to the SSP e85 tune and is supposed to be even faster.
    When I ran my SSP pump tune I was putting a lot of lengths on an APR stg 3 running a race file.
    It is very aggressive tuning, a decent a mount of boost and timing. I daily drove it for a while, until my headgasket blew. My new setup will be going back to Greg@SSP.
    Here are some pump gas SSP cars.
    http://www.youtube.com/watch?v=cqn5GPpD7RQ (old SSP tune)
    http://www.youtube.com/watch?v=wYeqACHx5h8
    http://www.youtube.com/watch?v=YTCi2E5xOIE
    Jan 28 2007
    Portland, OR
    So when you ran your tune, what was done to your car? What is your new setup consisting of if you don't mind me asking? Just trying to get a better understanding on how these cars react to tuning. Thanks for the links. Very nice.
    Oct 26 2008
    Stage 3 2001 S4, 2009 S5
    So Cal
    Have an 85 pound jockey drive your car. LOL!!! SHould be good for a 11.2, starve him for 2 days, maybe a 10.99
    Dec 11 2006
    Boston
    Well I know longer have the K04 setup. At that time though, it was PJ K04's, straight downpipes (no cats), straight 3.5" exhaust (no mufflers/no res). Custom FMIC with 2.5" piping. 630cc injectors, walbro 255 FP. 85mm VagMotorsport straight through MAF, 9" DryFlow Intake. Topped with a custom tune that had about 50 revisions since day one.
    The new setup is a built block with Pauter rods, 2.8 heads/cams with 034 intake/exhaust valves etc etc, TiAL 44mm WG, Borg Warner s372 turbo, pre-production single turbo manifold, custom FMIC, and Meth injection.
    That setup is almost done, but I am shooting for 600whp on pump. It will also retain ME7. It also hit up Jenny Craig for a nice little diet...still full interior though.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by grAh4m View Post
    PJ K04s just means "Plain Jane" K04s, i.e. no RS6 hybrids...etc.
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 15 2008
    Miami
    omg these thread repeats are endless..seeearrcchhhh...shit, peoples 11 sec times are in their sigs...youtube 11sec s4..garuntee u get something..then email the person who posted..or CALL vast, epl, marc, ssp, asp, etc etc etc
    and im not even being a dick its just these answers should come through track knowledge..the last thing these answers shud come from is forum bench racing..go to a track..talk to people...watch and talk to people who race s4's and are in or close to 11's
    Jul 26 2008
    Jersey
    Wanna run 11s? then do this..
    run your car now, see what it does.
    Go stage3 (tune of your choice) see what it does.
    Make appropriate mods to hit 11s
    There is no "formula" that ='s 11's.. you can be pointed into the right direction, but all S4's are not created equal.
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    you also need to have track experience to run 11's. Do your research and pick a tune, everyone on here has a different opinion on software, but you have to see how many of them actually went 11's in their car
    Dec 11 2006
    Boston
    Quote Originally Posted by 2001S4NY View Post
    Didn't Tommy run 11's with your tune, without any prior track time?
    Long Island, NY
    yes but he is "asian" he also has been driving stick for not a whole year
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    hahahaha
    2010 Brilliant Black/Magma Red S4
    Jun 14 2007
    2000 S4
    Connecticut
    Greg can tune your car so it runs 11's even when its off ! now thats powa
    Long Island, NY
    almost as good as a six flags roll a coaster ride
    Jun 14 2007
    2000 S4
    Connecticut
    lol. have you gotten my texts? my phone just died no more battery but can you text me a price for the aux. water pump replacement at the same time as the valve cover gaskets and all. thanks brooo!
    Oct 24 2008
    Louisville, Ky
    Quote Originally Posted by Dr.Duct View Post
    who is this guy??
    I'm DARKMAN!!!
    Ok, maybe not. Just throwing an opinion out there. They don't give out medals for hitting 11s, so I figure say whatever.
    Does that make me bad?
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Ha, someone should do what Marc did but with a KO3 car thats stage 2+. The results may be interesting. Has anyone done that before?
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    the piggies are fine i suppose, i havent had a chance to run my car, or get it dyno'd. but i would get epl if you have the money,with water-meth youll for sure get into that 400+whp after a good tune. which they tune some beast S' .....the 11's part is up to you though, it doesnt matter if youve got a 500hp car if you cant drive it good!
    your getting a new clutch and intercoolers as well?
    where are you going to get the k04 kit?
    '00 Nogaro Blue S4
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    go with marc 10secs4.
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    SSP has some fast cars, mine will be one of them.
    PS: Greg, what size pipe do i need for that intake?
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    So currently Im leaning towards Marcs fueling. Thinking about putting cutouts on the piggies. And going with a Clutchmasters, but which one for low 11's? And adding a W/M kit.......= Good for 11's?
    May 26 2008
    MD
    Quote Originally Posted by nocturnals4 View Post
    I thought about marks tune too. But than i went with SSP. I wanted a custom for my car not made by another company tune
    Veteran Member Four Rings So_NAudi's Avatar
    Jul 11 2008
    Dead Hookers, Kilos of blow and an asston of pokemon cards.
    43.07°N 87.97°W
    I'm DARKMAN!!!
    when i saw this i thought of nightman from its always sunny...
    http://www.youtube.com/watch?v=Ein8lELsXSE
    -Alex
    ¯\_(ツ)_/¯
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Dude, do u search at all on the forums, or simply just post aimless questions.....there have been dozens of threads about W/M and the gains in both Stage 2+ and Stage 3, same w/ Marcs fueling..... If you want more power, get bigger DP's than stockers, like ASP 3" or WMS Widemouth or even custom ones! Your clutch is dependent on how much power you are going to be putting down, so call the vendors and ask them!! Vendors are just as helpful as us, and they don't bite
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
