Results 1 to 6 of 6
    Registered Member One Ring SharkyS4's Avatar
    Jan 12 2007
    Fuel Filter DIY replacemen how to anywhere?
    Hi Guys,
    Looking for a how to on fuel filter replacement for an '05 S4. Also does anyone know the part number for this filter? An indy shop I called about doing this mentioned that there are 2 filters, one more expensive than the other...sounds fishy
    Thanks,
    -SharkyS4
    Jan 12 2007
    Re: Fuel Filter DIY replacement how to anywhere?
    Quote Originally Posted by SharkyS4 View Post
    Hi Guys,
    Thanks,
    -SharkyS4
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: Fuel Filter DIY replacemen how to anywhere?
    Why did you quote yourself?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Part number that is listed in my repair history (it was done before I bought the car) is 8E0201511J. Don't have a DIY but it should be pretty straight forward and filter should be located on passenger side somewhere behind the pinch weld.
    and just in case someone needs part numbers for fuel pump:
    8E0201511J Fuelfilter
    8E0906087R Fuel pump
    8E0919133G Washer
    4B0886373 01C Grommet
    Jan 12 2007
    Thanks for the reply!
    I was down at the dealer today, they had 2 filters available for 05 S4, the parts guy did mention that the "J" is the one I needed.
    Cheers
    -SharkyS4
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Yeah, I did mine recently, get the number off your current filter and have them look it up. Follow this DIY: http://www.audizine.com/forum/showthread.php?t=209938
    Yes I know it's for an A4 but they are the same...
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
