Results 1 to 21 of 21
    Veteran Member Three Rings iamproph's Avatar
    Jun 19 2008
    2012 Daytona Q5
    Going in for 55k service, some questions
    So I am heading out on Monday to get my 55k service done, I have the Audi One program thing where it is all paid for. I know they do routine stuff, change out the oil, check everything, etc. I got a couple of questions tho. Keep in mind the car is under CPO warranty.
    1: My headlights are very foggy and always filled with moisture, pretty much never goes away. Can I get them to replace the entire housing, or anything along the line to fix it under warranty?
    2: Will they check my rotors and pads, and if they need replacement, are they covered?
    3: I have a couple of upgrades, APR Chip, K&N drop in filter (I also removed my snow filter) and F.I DPs and Catback. I am assuming because this is normal maintenance that they shouldn't bring any of this stuff up, I can also hide my chip, but I do know that they are supposed to replace my air filter, do I just tell them not to?
    Thanks in advance, once this service is done I will start putting on my other upgrades, going with the Oettinger front grill and a new set of shoes + tires, woohoo!
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: Going in for 55k service, some questions
    1. Should be warranty
    2. Consumables aren't usually covered, but I'm not familiar with the One plan. They will check the pads and rotors though.
    3. The chip may raise a flag. AFAIK, from what I've read in the service bulletins, if they need to update your ECU they must notify you that it will erase the aftermarket programming. You will then be spanked by a ribald Tuetonic Queen with a leather paddle and sent on your way.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Established Member Two Rings notachance's Avatar
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    your headlights are not gonna be covered. i had the same problem and the simple o-ring mod fixed that so easily. search for it im sure you can find it.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Yea, headlights are absolutely not covered. Audi released a TSB but of course states that is not covered by any Audi warranty.
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by 40valve View Post
    Sorry, I thought someone said they got it covered, my apologies.
    The Avant Garde
    Senior Member Two Rings darbyfam's Avatar
    Dec 18 2005
    New Orleans, LA
    The brakes will be covered on B6.
    **2020 Audi Q8 Prestige, 034 Stage 1 ECU and TCU tunes, RFX11 22x10 wheels, APR Intake, Maxton front lip.
    **2018 Audi S4 Prestige, 034 Stage 2, ECS High Flow Cat, AWE Touring Exhaust, ECS Turbo Inlet, ECS Tuning Intake, EMD Lowering Springs, Avant Garde wheels.
    Registered Member One Ring SharkyS4's Avatar
    Jan 12 2007
    The headlights will not be covered unless the lens is broken, the fogging up is "normal". Their fix is to blow the water out with compressed air. I was told by a service advisor to call AoA and push the issue, maybe you'll get lucky... Do the O-ring mod, it works!
    -SharkyS4
    '05 S4 6MT Brilliant Red \ RS4 Pedals \ Neuspeed Sway Bars \ K& N Panel Filter \ Nuvi 350 and V1 Hardwire
    '08 A4 3.2Q Tip \ S Line \ Titanium \ Everything
    Past Audis '72 Audi 100 C1(first car), '97 A4 2.8Q Brilliant Black / '02 ALMS TT Misano Red
    Jun 02 2008
    Petaluma, CA
    Last weekend it was raining in the bay area and my lights foggged up pretty badly. I had taken it to the stealership before and they had told me no dice. However, this time I told them that it was a safety issue and that there was such a thing as normal and excessive. Long story short they are replacing the headlamp housings.
    Jan 12 2007
    Quote Originally Posted by amremt View Post
    are you still under warranty?
    -SharkyS4
    Jun 19 2008
    2012 Daytona Q5
    You sure the brakes are covered on my B6?
    Jun 02 2008
    Petaluma, CA
    Funny you should ask. I took it in the day before my 4 year 50k warranty expired and Joe at Carlsen really went to bat for me.
    Jul 22 2008
    2005 B6 S4 (6MT)
    Rhode Island
    Quote Originally Posted by iamproph View Post
    I don't think the brakes are covered .. highly doubt it.
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Headlights not being covered is ridiculous. They should be.
    I think we should all call AoA and make an issue of this.
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Established Member Two Rings Longfist86's Avatar
    Nov 01 2008
    08 MkV GTI, 09 Jetta
    Dade county
    brakes wont be covered on an aftermarket warranty only the factory warranty on a B6. with the headlights its normal condensation.
    they will however check everything they can to upsell work.
    i dont think there are any flashes for the ECM on that model.
    Just take care of your service Guy and im positive he'll take care of you.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    ^ correct, my B6 brakes were covered until the 4yr -50kmi factory warranty ran out. After that, you are on your own!
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Jun 19 2008
    2012 Daytona Q5
    I would if I knew who I was going to have. This is the first service since I bought the car in Denver, now I am living in North Carolina and have to drive an hour to the closest Audi dealership up in Raleigh. So I have no idea what to expect when I get up there, I know the second I pull up in my full F.I exhaust they will know my car isn't stock and I expect them to try and screw me. O well if they are cool and will help me out hopefully at the least with my headlights I will be happy. And my headlight condensation is nothing normal I can assure you. Both sides are entirely covered with water at all times of the day, whether it rains or not, and even when I turn on my headlights and let it sit nothing goes away.
    Veteran Member Three Rings SebringSilver's Avatar
    Oct 04 2006
    TT RS
    Vancouver, Canada
    I just had my 55K service last month. They did indeed check brake pads and rotors, and no, they didn't cover the replacement cost of the rear pads (which were down to about 3 millimetres).
    Currently Driving: '18 TT RS | '18 Velar P380 HSE First Edition
    Gone and Missed: '18 TTS | '14 991 C4S | '11 R8 V10 | '09 R8 V8 | '09 C63 AMG | '06 B7 S4 | '94 NSX | '92 NSX
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Im scheduled to bring my car in for the 55k service this week. If you haven't already, I'll post up what u want to know after.
    Veteran Member Three Rings UltraS4John's Avatar
    Sep 16 2006
    2013 Audi S4
    Northern VA
    To get your headlight replaced + failed inspection = possible new headlights
    That's how I got mine replaced. State wouldn't pass due to condensation.
    2013 Audi S4 - Brilliant Black (Prestige) DSG + IE Stage 1 & STaSIS exhaust
    2013 VW GTI - Carbon Steel Gray Metallic DSG + APR Stage 1 & AWE exhaust
    2018 Audi Q3 - Daytona Gray Pearl DSG
    Jul 22 2008
    2005 B6 S4 (6MT)
    Rhode Island
    Quote Originally Posted by ieatfishburitos View Post
    What is covered? Surely not the pads .. I have a certified pre-owned up to 100K ... am I covered under that?
    Sep 16 2006
    2013 Audi S4
    Northern VA
    oil change
    replace air filter
    change spark plugs
    "inspect pads"
    usual fluid checks as well.
    tire rotation
    You can do all this on your own as I did...
