Results 1 to 7 of 7
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    gauge cluster center display warning lights
    hey everyone, i have a quick question.
    I have a terrible center display in my gauge cluster... so i cant tell what the little yellowish lights on the top 1/4 are thrying to tell me : \
    I got real low on gas, and i could tell it showed a pump
    but i was on the interstate cruising in 5th, about to pass someone so i kicked it down for about 10 seconds or so and the top 1/4th of the center display lit up (i usually have it on off (all black) mode). It had a kind of circular shape to it, i cant really tell too much more than that, but it did that twice, both times right when i was passing another car and having help the pedal to the metal for a bit. could it be oil light or something?
    If anyone knows if there is a list or anything of the center display warning symbols maybe i can narrow it down from there
    thanks and info will help
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Re: gauge cluster center display warning lights
    break pad warning... mines on always
    __________________
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    (()) if it was something like that. a circle surrounded by parenthesis. it is your brake pad sensors. so your pads might b running low. i just had the same problem, changed my pads with some new ceramics and viola.
    if you search there is a list somewhere of ALL of the little icons that appear on the top of the display.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Sep 01 2005
    Quote Originally Posted by le91688 View Post
    beat me to it. why is yours always on? no sensors on the pads?
    Sep 22 2008
    Minnesnowta (Roch)
    why would it only come on at the peak of my acceleration? i never hit the brakes or anything.
    anyone know where that list of icons is? thanks
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    km/h speed warning?
    Possibly you accidentally enabled the accoustic / visual yellow speed warning, whereby the display shows the km/h symbol once the preset speed has been reached / exceeded.
    Usually accompanied by a "beep."
    Sep 22 2008
    Minnesnowta (Roch)
    its never done that before though? and i have gone much faster
