Results 1 to 4 of 4
    Mar 05 2006
    2002 A4 1.8t
    San Diego
    help with overheating
    About a week ago I was driving and my car started beeping so I look down and it says CHECK COOLANT LEVEL and the temp is at H, I pull over to see whats up and the coolant is low so I open the cap and it steams then goes back up to normal levels- Im like WTF?! I get in the car and its fine for about 15 mins, then does it again. I get home and turn off the car. I put more coolant in and its fine for a day, then does this little dance again. I checked the forum, thought it was the thermostat, changed the pain in the ass thermo, the car still does it. Coolant levels are fine, but now it gives me the error and car is at H within 5 mins of driving or maybe a mile from home, but only randomly. What do you guys think?
    also I called my mechanic and he said he doesn't think its the water pump because it wouldn't be overheating so quickly or randomly. Second its not leaking and the coolant level is fine. Any help is much appreciated.
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    Re: help with overheating
    aux water pump, water pump, rad., warped head. mine was all of the above
    Dec 06 2007
    water pump. rusted from infrequent coolant flushes. no matter what u do unless u do a Timing belt and water pump ur shot. Happened to me i would let it cool add water, and drive 1 block boom overheated.
    -Kirk
    BetaAlphaTau Member #58
    Mar 05 2006
    2002 A4 1.8t
    San Diego
    damn it I was hoping it was just a bad sensor, the car runs fine, even when it says its overheating.
