Results 1 to 14 of 14
    Established Member Two Rings skoo74's Avatar
    Apr 22 2007
    Sacramento, CA
    Can Vag Com resolve Alarm Chirp issue?
    My car alarm does not chirp when I press the lock button on my remote. Is there a way to enable the chirp after pressing/enabling the alarm? Is there a Vag Com tweek code I can use to enable the chirp?
    Apr 22 2007
    Sacramento, CA
    Re: Can Vag Com resolve Alarm Chirp issue?
    up for answers/suggestions...
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    I'm pretty sure I remember reading somewhere on a list of options about being able to turn that off and on.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Jul 06 2008
    red rock or new braunfels
    yes you can change the alarm armed sound
    Aug 26 2005
    Yep, I think it's either a coding option or an adaptation channel value in the Comfort/Conveinience Module. If for some reason it's disabled, it can be re enabled. More likely, is that the alarm horn is bad.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Yeah, if it has worked in the past, your horn module is probably bad. That thing has its own battery inside AFAIK.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Apr 22 2007
    Sacramento, CA
    Quote Originally Posted by gtimart View Post
    oh really? I just tried to enable the chirp and nothing.. it must be the horn... anyone have a diy fix for this problem?
    btw, I bought the car used and never heard the chirp... but realized there's suppose to be an alarm chirp and now want the confirmation it gives.
    Sep 13 2007
    Quebec, Canada
    I think the "fix" is to replace the module.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    yeah, damn things like to burn out, had that happend to me on 2 (TWO) audis
    Apr 22 2007
    Sacramento, CA
    Thanks for the replies... anyone know where this chirp horn located? and is it the same one as the car's horn?
    Aug 26 2005
    It's a dedticated unit located in the lower right rear corner of the trunk under the side panel, and is mounted to sound off through an opening under the bumper.
    Dec 06 2007
    ^^John is the panel visible and easy to get to? or very difficult?
    -Kirk
    BetaAlphaTau Member #58
    Oct 08 2007
    Columbus, OH
    you gonna have to remove liner in your trunk or atleast get it out the say, not hard but time consuming
    Apr 22 2007
    Sacramento, CA
    I found this.. http://forums.audiworld.com/a4gen2/msgs/1004828.phtml
    I'll follow these instructions when i get a chance...
