Results 1 to 18 of 18
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Is an exhuast necessary?
    I'm getting APR stage 1 + with fuel injectors. Also an FMIC and water/meth injection. What will I be losing if I don't upgrade the exhaust. What will I gain if I upgrade it? I don't want to pay over $300 for an exhaust. If I REALLY need an exhaust, would a electric cut out work? They are cheap and from what I know relieve all back pressure. What about straight piping it? I want performance, but I don't want to spend a lot on the exhaust.
    Thanks
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    Re: Is an exhuast necessary?
    y not go with stage 2 if you plan on getting a fmic?
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by italainboy1032 View Post
    is that just a tune?
    Stage 2+
    Oct 27 2008
    Montgomery TX
    anyone?
    Stage 2+
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Stock exhaust is fine. I changed exhausts from stock about halfway through having 1+ and didn't notice anything but better sound. Even my EGT didn't change. I was running a Miltek HFC, though with both exhausts. The nicer sound, of course, makes you FEEL like you're faster. I call it the "Carbonio Effect".
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Ehhhhh... Here's the deal.. from what I've felt/noticed in my car there's 2 things that need to be removed to gain power.
    A) Replace the stock cat with a test pipe
    2) ;) Atleast get rid of the suitcase mufflers in the exhaust. Problem with this is it doesn't sound good.
    You really do want to get an exhaust. If you want to do it on the cheap.. here's what you do. Order a Magnaflow muffler (not one with a tip.. just one with an inlet and outlet) Remove the stock pipe at the sleeve and cut off the resonator. The stock pipe is 2.25" so it's really not that far off from a 2.5". Weld the muffler where the resonator used to be and go to an exhaust shop and have them do a Y pipe to the tips of your choice.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by phantom b6 View Post
    I was planning on getting a test pipe.
    Also what is the difference between stage 1+ ecu and stage 2 ecu. What will I need
    Stage 2+
    Apr 02 2008
    LA
    There is no Stage 2 for APR... they just have 1+ and then they can recode the ECU to get rid of the CEL from the test pipe
    Oct 17 2007
    mass
    stage 1= chip
    stage 1+ chip +injectors
    stage 2= chip +injectors+ plus anything else exhaust dv fmic etc
    Feb 28 2006
    Pittsburgh-Philly
    Shit, then some of us have a stage 759.4
    OP, don't worry about the stages. I can't talk you out of even worrying about the 1 and 1+ stuff, as everyone wants to start with that... but you'll find it slow as balls after a week of thinking you're faster than hell.... then some soccer mom in a Caravan still whips up on you. Then you want a bigger turbo and will be pissed you just didn't do that in the first place.
    Watch for TP if your state does visual inspections. You'll have to swap back out for the cat every time an inspection comes.
    On 1 and 1+, you ain't gettin' much but sound when you replace the exhaust. It's the cat that needs free'd up.
    EDIT: I never saw that you're trying meth. You should free up a little more in the exhaust as you add on to the 1+, but I still say start with the cat replacement. But still, just go balls out and upgrade the turbo. I wish I could think of a comparison/analogy of what 1+ with Meth would be like.... I mean, that's great you're doing it, however with APR, you're stuck on your timing that they give you, unless you know how to use Unitronics or Lemmi, so meth won't be like a nawz shot, yo... Something like- "A stage 1+ with Meth is like __________". Maybe "just sticking the tip in", lol
    Dec 06 2007
    stage 1= chip
    WRONG!!!!!!!!
    Stage 1+=chip+injectors, and the numbers are calculated with an FMIC, an exhaust.
    Stage 2= K04 Turbocharger, whole new file, and all the helping mods.
    -Kirk
    BetaAlphaTau Member #58
    Oct 29 2005
    10speed
    San Francisco, CA
    you dont need a FMIC and meth
    - Clint
    Dec 06 2007
    ^^well an FMIC or upgraded SMIC is not necessary but recommended it does make a huge difference.
    -Kirk
    Oct 17 2007
    mass
    Quote Originally Posted by AudiA4Turbo22 View Post
    WRONG!!!!!!!!
    i thought k04 was considered stage 3
    Dec 06 2007
    ^^stage 3 is BT.
    -Kirk
    Oct 29 2005
    10speed
    San Francisco, CA
    - Clint
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    ^^ lol! Clint, you're ER Comp FMIC you're selling has the k03/k04 piping right?
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Oct 14 2008
    2003 A4 1.8TQ-M, 1990 300ZX TT
    Long Beach, CA
    Just make your own exhaust. Testpipe, some cheap mufflers (if you care for any sound), and an exhaust shop will do you well. Still might come out to more than $300 with labor and such.
    Stage 1 = chip
    Stage 1+ = chip+ any other mods without a turbo upgrade
    Stage 2 = K04
    Stage 2+ = K04 with other mods
    Stage 3 = BT at 270-350 chp
    Stage 3+ = BT at 350-400 chp
    Stage 4 = internal/head work making 400-500 chp
    Stage 5 = Stand alone or making 500+ chp
    Taken from the B6 A4 Ultimate Performance Noob Writeup/FAQ
    Some here should take a look at that thread.
    2003 Audi A4 1.8T Sport Quattro 5 Speed
    ~~VMR V710's 19x8.5 +35 * Sumitomo HTR-Z III 235/35/19 * Bilstein Struts * Neuspeed Springs * Boosted Technology CAI * GIAC Tuned * Audi TT Diverter Valve * AMS Short Shifter * 35% Tint * Clear Signals~~
