Results 1 to 8 of 8
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Put on some different brakes...happy so far!
    I put on some 2002+ A6/Allroad ATE calipers and matching rotors (321x30mm). So far so good...a nice improvement over my 3.0l upgrade which while to date was satisfactory is no longer so (at 25psi spike and holding 25 i had quite a bit more "go" than i did "stop"). Some new and improved pads will come springtime for some track duty, but overall I am pretty happy with the upgrade so far!
    thought I would post this up...its another alternative to HP2 setups without the 8-pad system and equal or better stopping power!
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Re: Put on some different brakes...happy so far!
    How much did this setup run you?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I thought the A6 caliper were the same as as the HP2 setup
    -Sami-
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    When HP2 "warpomatic" was discontinued alltogether, the ATE was the replacement starting in MY 2003. These were used also in later allroad 4.2l cars, a6 4.2, etc. 4 pad system as opposed to 8 pad. Pretty easy brake to come by and has nice beefy (read big and heavy) rotors. Was a nice bolt-on OEM alternative to HP2, which I personally was never a huge fan of.
    USP CLUB MEMBER #26
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    Sorry for reviving an older thread. Do you have pictures of these ATE calipers? I'm trying to figure out what I have on my C5 (2002). They don't look like HP2 calipers but it was my understanding that 2.7T C5's had HP2's until 2003.
    Perhaps I have a later 02 with the new caliper or a single piston setup...
    thanks,
    Ian
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Quote Originally Posted by mtxsho93 View Post
    thanks,
    Ian
    sorry about how dirty the car is, havent really attended to it to much lately with snow looming. Hopefully this angle gives you a good idea!
    USP CLUB MEMBER #26
    Sep 20 2008
    South Jersey
    Quote Originally Posted by DenverNoob View Post
    Thank you! This appears to be what I have on my A6. So you're saying that this is an improvement over the HP2 caliper? Are they single piston or dual piston calipers? Sorry - I've only had the car a short while and haven't done much more than change the oil on it. I'm thinking of putting less dusty pads in there soon.
    Ian
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    1 pot, 2 pad (per caliper) setup. the older HP2 used 4 pads per caliper and had a tendency to warp rotors and wear unevenly as a result.
    additionally, at 321mm x 30mm, the rotors for these are a hair larger and more effective. overall a nice improvement of the HP2.
    USP CLUB MEMBER #26
