Results 1 to 6 of 6
    Nov 04 2008
    Fort Lauderdale
    Audi 90 Manual tranny to A8 4.2 V8?
    Hi,
    I'm an Audi newbie so please pardon my ignorance. Will the manual transmission from a 93-95 Audi 90 Quattro bolt up to the 4.2 V8? If so, will the flywheel bolt up as well?
    I tried a search here to no avail.
    Thanks in advance for any advice.
    Aug 26 2005
    Re: Audi 90 Manual tranny to A8 4.2 V8?
    Try asking on the 90 and or A8 forums.
    Aug 06 2008
    Canadia
    I dunno if it helps, but a audi guy i know is running a B5 S4 manual tranny in his mid 90's (1996?) RS6
    the B5 S4 is like the mafia... there is only one way out!
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    you should ask on audiworld or something. The classic Audis and A8 population here on AZ is extremely low.
    TEAM|AXION
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    It should fit.
    I know a guy that pulled a 2.8L out of a 90 Quattro and dropped in a V8. The Coupe Quattro trans has the same bolt pattern as well, those have had more than one V8 swap.
    The multi-bolt pattern Audi trans should fit.
    That being said. The flywheel is different. It will fit in the bellhousing, but the the actual flywheel itself has a different bolt pattern.
    May 16 2008
    South Texas
    Quote Originally Posted by surfpac View Post
    Hi,
    It will bolt to the engine but the torque of that engine will quickly make scrap metal out of that transmission. (in other words don't do it).
    Quote Originally Posted by MacDaddy View Post
    That can't be, the B5 transmission will not bolt up to an RS6, and the RS6 was made in 2003.
