Results 1 to 6 of 6
    Nov 03 2008
    Boston
    What in the world is that noise?!
    Ive noticed that whenever Im driving there is a significant amount of noise coming from the back of the car. It sounds like a reving noise. I know the intensity is proportional to the RPM of the engine.
    When I take a sharp turn, the car shudders and Im wondering if these two symptoms are related. I know the shuddering is because of low differential fluid. Could the other problem be the same??
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    Smile Re: What in the world is that noise?!
    Hey Mr Boston, :) I had, what seems to be the same issue as you....does it get louder and louder the faster you speed and increases....then when u reach a certain speed the sound stays at about the same sound decibal? I took it to dealership and found out that it was my right-rear wheel bearing!!!(it was beat to hell)
    thanks, i hope this helps corey
    Apr 26 2008
    White Plains, NY
    Does the noise increase even when reving the engine in PARK/NEUTRAL?
    Aug 13 2008
    Indiana
    Quote Originally Posted by rockpundit View Post
    So you know that you have low differential fluid and your still driving? It's most likely a wheel bearing.
    -Nic
    Registered Member Two Rings
    Feb 27 2004
    Marianna, PA
    Wheel bearing!
    A4 1.8T quattro sport, 5-speed - 1998
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    Does the noise go away when you take load off that corner.
    Right Rear : Turn Right, weight shifts to left side of car, and noise goes away.
    Left Rear: Turn Left, weight shifts to right side of car and noise goes away.
    If it is a wheel bearing, fix is fairly simple...
    1. Buy new wheel bearing for that corner ($60)
    2. Jack up car
    3. Remove Wheel
    4. Remove Wheel bearing housing (The big steel parts connected to everything)
    5. Take to shop to have them replace wheel bearing ($40)
    6. Install housing
    7. Get alignment (Free, if you have the alignment coverage since your last paid alignment...)
    Might be cheaper if you take it to a shop to have them just do it on the car, though, they may want you to buy the bearing there, and they may still charge you for an alignment...
    1998 A41.8tqms
