Results 1 to 3 of 3
Thread: Audio questions
    Jan 10 2008
    98 a4 quattro
    New Jersey
    Audio questions
    i have a 98 b5 a4 with non bose and i want to upgrade my speakers. I am thinking of bypassing the rear speaker amp by sending the wires right from the kenwood headunit to the rear speaker. Do you think this is a good idea and will it also work up front?
    Throttle pedal meet floor board
    K04 meet (pc16 + n75h)
    Honda's meet taillights (Im not a hater I had a integra)
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: Audio questions
    Quote Originally Posted by quatrroking View Post
    That's how mine are hooked up. I didn't do it though, the previous owner did. It works just fine. I'm planning on upgrading the speakers soon so it should make it easier. The front speakers on my car are still hooked up the stock way though. Just the rears were re-wired.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Re: Audio questions
    Yes and Yes.
    You really should upgrade the speakers if you want much better sound.
    Then if you want to get the most out of the upgraded speakers you should amp them...
    then if you want to have the best full range you should get a sub....
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
