Results 1 to 40 of 51
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Possible Boost leak...
    So i was looking for a possible boost leak even though my boost i guess is normal and i cam across this which looks like it has to little tears in it.
    what is this peice and what does it do?
    A Close up of the wire/ Vac hose or whatever this is...
    any suggestions???
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Possible Boost leak...
    also does my T-Fitting for the boost gauge look ok... the T fitting i was supplied my awe tuning with was REALLY hard to get the tubing on even when i used wd-40. that was the best i can do before tearing it...
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    I'm pretty sure that's the electrical plug for the n75 .... no air runs through that.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    oh well if thats the electricla plug then i couldnt have a boost leak... i guess...
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Im not sure what that is, it wouldnt cause a boost leak though. I think the N75 is orange, but it is a plug just like that.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by phantom b6 View Post
    the N75 valve is on the passenger side of the motor right next to the accordion hose
    follow all 3 arrows pointing to N75....
    I cant see because the picture you provide is so zoomed in but you may be looking at the N249 valve there.
    Jun 14 2007
    2000 S4
    Connecticut
    and that's fine for the T fitting ... what kind of boost gauge.. if you are truly worried, which I always like to be sure everything is tight, go to your local autopart store and simply buy a smaller T fitting... any will do the trick, if you want the gauge not to fly around so fast you can get one with a resistor in it, ECS tuning sells them.
    what is your boost doing that you asked about a leak?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    well i was doing some runs yesterday and the first time i did it i was going 40 and punched it and i have it on the stock setting and the boost went to like 6-7 then up to 8-9 then as it was getting near the redline the boost dropped to 6-7 then after the shift back up to 8-9.
    on my second run i punched it going 40 again and it went straight to 8-9 then as it was getting near the redline the boost dropped to 6-7 then after the shift back up to 8-9.
    i think i might be worrying to much but does this sound right?
    May 31 2008
    New York
    Sounds normal to me...I believe boost drops at or near redline. Someone correct me if I'm wrong
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i got the awe vent gauge.
    Jun 14 2007
    2000 S4
    Connecticut
    Yes it is 100% normal for boost to drop at redline... The reason this happens is because higher up in the RPM range your car is demanding more and more fuel, and to keep a safe A/F ratio the boost drops a bit so the car doesn't run lean..
    I made this video well over a year ago when I had a slight boost leak, but do you see how the boost is tapering up top?
    http://www.youtube.com/watch?v=dTF8HPXZpLc
    that is what I'm talking about, it is not only normal but mandatory! if your boost keeps rising its called boost creep and its not good!
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    wow yeah i see your gauge is going nuts lol. Anyways what does your Giac X Ecu run at psi wide? Im gettin 14-15 but people say 16-17 which gets me worrying a bit...
    Oct 31 2005
    Ashburn
    Time to start pressure testing, Giac X spikes @ 18-19psi and tapers down 2 15 by redline.
    - Instagram: @Sinister_rs5-
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by 00s4slvr View Post
    well that video is over a year old, i have a stage 3 now with a VAST tune... But in that video, where I thought I had "bad gas" it was actually my F hose that crapped out on me, and lead to my turbos going byebye.... GIACX should hit around 18-19 just as HighPsi said and taper down 14-15. You may get a slightly lower spike in colder weather as the N75 will adjust since colder air is more dense leading to less boost = same amount of air as high boost in less dense air
    Jun 14 2007
    2000 S4
    Connecticut
    change your dam avatar! you taught me, now go! I want to see that sexy new look you rock lol
    Oct 31 2005
    Ashburn
    I'm waiting to get some better pics, i don't like the ones i have.
    I still get intercooler questions because of that avatar :0)
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    my boost has been acting strange lately as well Vacuum at idle is around 18-19psi, but sometimes boost is where it should be 22psi tapers to around 19 at reline, but sometimes it is around 18psi and tapers to 15. K04's APR chip APR fueling. Boost leak maybe? or could it be dirty MAF? Still on stock intercoolers
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by sti4now View Post
    I would look into the boost leak. Pressure test that sucker. No way should you be only holding 15 at redline sometimes stage 3.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    well i have no idea how to pressure test and you dont think maybe my N75 is faulty or my diverter valves... Why would my boost be low on pump performance but if i have it on stock mode its compeltely fine?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    what about me? on pump performance my boost will be steady 14-15 psi then spike up to 17-18 then taper back down to 14-15.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    also i have a tip
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    thats not right. your n75 could be failing.
    if you have to take it to a shop to get it pressure tested then do so. all a pressure test is is hooking a fitting up to your maf and running air through your system. u will hear a leak.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    how hard is it to change the N75?
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    And why would my boost be normal on stock mode but chipped be messed up?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    jeezus think about the questions you are asking before you post.
    look at the location of the n75.. does it look hard to change?? try it then ask.
    and uhm if your valve is failing that means it wont be able to hold the higher boost pressures of a aggressive file. stock is whatt 8 psi or something?
    since im guessing a MBC would be over your head, buy this;
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T (ECS - Race N75 Frequency Valve)
    its a worth wile upgrade.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    well i guess it shouldnt be too hard then since i changed my TBB myself and that came out okay, so im thinking would i be able to do the N75 and Diverter Valves...? Also im low on money and i dont know any shops around here that would pressure test my car... It just doesnt make any sense why my Boost woould be normal on pump but on stock its ok...
    Oct 31 2005
    Ashburn
    Because the higher the boost the more pressure is bulit up/ Hence the boost reading PSI- Pounds Per Square inch. 8-9 psi might not be enough pressure to cause a leak to become visible or be noticed, the higher PSI levels will cause leaks or tears in hoses to become more noticable. That's why you see the fluctuation. Boost is leaking/escaping out of a hose/or other boost holding related object. There's more to it but i hope you can understand with what i wrote.
    Are there local meets,shops in the area? I would get someone to help you pressure test. If you can't understand the logic you shouldn't try to do it yourself and you should do alot more reading on the board as there are alot of helpful threads.
    Alsosearch there are countless threads on boost leaks and pressure testing with instructions on how if your up to do it yourself.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    didnt i just say this?
    Oct 31 2005
    Ashburn
    Quote Originally Posted by ThirdStrike View Post
    You did but, i didn't say the same qoute for qoute. I don't think he still would have understood, i tried to break it down a little more. hopefully he'll get it.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Would it be worthwhile to replace the N75 valve on a car that isn't necessarily acting strange but more of a precaution?
    Same thing I guess as the DV's and TBB. Most ppl don't wait until they fail, they replace them before that happens - is it the same with the N75 valve?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by CONTROL ONE View Post
    the ecs "race" valve seemed like a better solution to me. id say get it.
    he needs to read and stop asking redundant questions jeez
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    ok so i ordered the N75 Race valve and the Bosch 710n's. My questions is, is there a write up to install the Dv's? How hard is it to install those? I have been getting mixed reviews, some people saying there a PITA and some saying there easy like cake...
    Are they hard to install?
    Jun 14 2007
    2000 S4
    Connecticut
    how long does it take you to get to westchester area in new york? if you want I will install them for you, no cost just to help. if you want.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    man dont pick up a wrench for this guy/kid. instruct him. he wants someone to do the work for him
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Hey thirdstrike what the hell is your problem im sorry im still learnin...
    And audisportb5s4 im gonna be picking up a borla exhaust that i just bought from a guy on the forums (borla!!!) and he lives in westchester so i will be there this weekend, but the parts wont be here for probably a week... there coming from ecs tuning.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i dont want anyone to do the work for me i want someone to teach me/ guide me how... i dont see whats wrong with that...
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    yeah if you wanna help that would be great and i am gonna have to pay you something because i cant just let people help me for free thats just rude.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    all im sayin is try doing it yourself. its really not that hard.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i am going to... its just nice that he offered to help me...
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i am going to i just asked if anyone knew if there was a write up for the Dvs or N75?
