Results 1 to 14 of 14
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Thinking about getting Water/Meth Injection
    I have an 04 A4 1.8T with multitronic and stage 1 apr. I am getting Audi tt225 386cc injectors in a little while. I was also thinking about getting water/meth injection. Would I notice power gains? Is it safe on the engine? I do have a 93 oc. and 100+ oc. tunes on my tuning. Would I need to get it retuned. I know I could run it on 100+ all day on 93 octane. How much power gains would there be? What kind of kit do I need? (Preferably under $400) Would I be able to install it myself with basic knowledge? Does it spray the whole time you're driving, or just when you flip a switch or when you are on the gas? And one last question, how often would I need to refill the water/meth tank, and do I fill it with just normal winshieldwasher fluid?
    Thanks,
    Search feature didnt help much
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Thinking about getting Water/Meth Injection
    Hey Cameron... I have the exact same car as you.. CVT and all.
    First thing you're going to want a FMIC.. you're going to need the metal piping to tap the nozzle for the meth. With a FMIC+Meth my Intake Temp was 44*F when the outside temp was 60*F
    I noticed a GREAT gain with adding the meth kit and advancing my timing with Lemmiwinks. I did a timed run last night with a friend and a stopwatch and my rolling 5-60 time was 5.1 seconds.
    I got the Snow Performance stage 1 ($300) and you hook up a vacuum line to it, and you can adjust it so it sprays at boost. I have mine set to like ~11psi. I use my windshield wiper reservoir and 1 gallon lasted me over a month. You CAN use windshield wiper fluid... but I was able to advance timing a bit more with the 50/50 "Boost Juice"
    I say that Meth is definitely one of the best bang for the buck mods you can do.. definitely the most underrated.
    OH.... I just looked at your sig and your mods. You're going to want to complete your bolt ons first and then add meth. You'll feel the biggest difference. Get the 1+ reflash, FMIC, and Exhaust.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by phantom b6 View Post
    Thank you very much, that was very helpful. 5-60 in 5.1?! Daaaaaang! Now what is Lemminwinks? And how do you advance your timing? And how will I know what timing is right? Are you running a 100+ tune? And is your FMIC an ebay FMIC? How much is Lemminwins or whatever it is that I will need to get?
    Thanks again
    Stage 2+
    Apr 02 2008
    LA
    Lemmiwinks is a free program created by Revo... just google it you'll find a ton of info about it as well as a download link. You're going to need a VAG-Com USB cable. The one I got was $30 from eBay and lemmiwinks worked fine with it.
    What you'd want to do is use VAG-Com to record data on a few pulls and then use that data to judge how much to advance your timing. To advance the timing, all it is is clicking the up button in Lemmiwinks and saving it to your ECU... but you have to make sure you've got the right amount.
    Yes I have an eBay FMIC. It works great. If/when you get the meth kit and the rest of your boltons, just PM me and I'll help you get the logs and I'll review them/compare them to my setup and get you some power with advanced timing.
    Oct 27 2008
    Montgomery TX
    Awesome!
    And I already have a VAG-Com usb cable! So that works out great.
    You've been so much help. Thank you so much.
    How hard and how long did it take you to install the kit? And with the ebay FMIC, how did you mount it?
    I also need to know where I can purchase fuel injectors for my A4, if you know a place off the top of your head.
    I should be getting and installing everything around December. Temperature will be around high 40's to low 50's.
    Thanks again
    Cameron
    Stage 2+
    Apr 02 2008
    LA
    LOL high 40s to low 50s in December.. damn Texas. It'll be 25 here haha.
    Anyway... It wasn't really hard but I've done a lot of mods and am comfortable doing pretty much anything with my car aside from an engine pull. It took me maybe 4 or 5 hours but that's because there's a lot of wiring involved and I soldered and heatshrunk everything and tried to make the install as clean as possible. You can barely see two wires running down the side of the engine bay whereas there's like 10 in the harness.
    Fuel injectors -- www.ecodetuning.com get the Siemens 380cc for $250
    Oct 27 2008
    Montgomery TX
    Haha yeah thats whats great about Texas!
    You've pretty much sold me on this. I too am comftorable with most mods so I don't really think it will be a problem.
    Okay so prices;
    Fuel injectors - $250
    eBay FMIC- around $200
    Electric exhaust cut off - $150
    1+ tuning - free!
    Then MEth injection - $275
    So a total of $875
    Not bad
    Thanks so much Phantom b6
    I will now finally be able to smoke my friends gt.
    haha
    Stage 2+
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Quote Originally Posted by ConroeA4 View Post
    Okay so prices;
    1+ tuning - free!
    So a total of $875
    Not bad
    haha
    Exhaust cutout is a bad idea you will loose 5-12 hp,I have this proven on a dyno.. just get full exhuast ..Dont be impatient get quality parts, our cars dont respond well to cheap mods..Snow performance makes quality kits heres the link to the stage 2 http://www.snowperformance.net/products.php?p_cat=158
    Jul 08 2008
    04 A4 1.8T
    UK/HK
    Hi Conroe
    5.1secs is pretty good!
    Is your A4 the 190bhp or 163bhp version? Can the CVT take so much power?
    Thanks
    J
    Thanks again
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    Okay so prices;
    1+ tuning - free!
    So a total of $875
    Not bad
    haha
    ConroeA4,
    So what part of Conroe are you in? I'm near the Woodlands, I live in Benders Landing. I've been looking into the Meth. inj. also and it sounds like the hot setup but where did you find it for $275. On the Snow Performance web site it $450 (stage 2).
    BTW....lets see a pic of your car so I can identify you on the road.
    Mines pretty plain, the only things visible that are different on mine are the x-drilled and slotted rotors (just did the rotors) and the Remus exhaust. I have some 18" wheels but they need refinishing.
    Apr 02 2008
    LA
    Quote Originally Posted by jc_333 View Post
    Hi Conroe
    Thanks
    J
    The CVT is the 163bhp version. Yes it can take the power... My car has no noticeable changes in driving and pulls (very) hard.
    Apr 02 2008
    LA
    Okay so prices;
    1+ tuning - free!
    So a total of $875
    Not bad
    haha
    You will pull a GT The other night some ricer flies up next to me and then just decided we were racing so he begins to pull away as I'm doing 60. He gets a couple car lengths away so I went for it and within 5 seconds I had reeled him in and put a train on him.
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by 80CID View Post
    ConroeA4,
    I actually live in Montgomery, it's right outside of Conroe. But I still live on lake Conroe. The stage 2 kit is not nescesary unless you are trying to shoot for 350+ hp. Go on snow performance and go to products instead of by car. It is 275$. I have a dolphin grey b6 A4. I have check my sig. for my mods. Nice looking car btw. I will upload pics later. It's nice to know I have someone around my area.
    If you ever need help installing something or doing some kind of mods give me a hollar! I would work on my car everyday if I could afford something different to put on each day. Haha
    Stage 2+
    Houston
    Same here, if you ever need a hand with anything shoot me an email....I need to get away from the wife and kid every now and then.
