Results 1 to 2 of 2
    Veteran Member Three Rings durrmcdanks's Avatar
    Feb 25 2008
    S4,RS4
    MN
    B6 s4 fault code
    My 04 s4 is throwing 16815 fault code involving a upper thermal bank problem. I was wondering if this was caused by the cat or the oxygen sensor. Does this hinder performance too and is there away around by getting a new sensor or straight piping and getting o2 sensor spacers? Please help thank you
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    That code can cause crappy fuel mileage and poor performance
    That code is for either of the 2 Oxygen sensors (front of Cat or rear) or the Cat itself.
    Diagnostic procedures say to test each sensor first, then once the sensors verify they are used to test the Cats.
    Failed sensors or clogged Cats can adversly effect performance.
    I would not neglect this issue.
