Results 1 to 4 of 4
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** 034 Ms - South Bend Clutch Group Buy ***
    034 Motorsport.com brings you another GREAT deal savings event.Just in time for election 2008 so that you can celebrate by buying your lovely A4 a new clutch set up.
    What better way to spend the next 4 years?
    Group Buy is being run for South Bend's HD STREET SERIES.If you want the Track Series simply send me a PM.
    Audi - A4 HD Street Series
    01A 5-speed & 01E 6-Speed
    THE SHORT:
    Stage 1 - 220 ft./lbs. of torque
    Stage 2 - 290 ft./lbs. of torque
    Stage 3 - 300 ft./lbs. of torque
    Stage 4 - 450 ft./lbs. of torque
    Stage 5 - 576 ft./lbs. of torque
    THE LONG:
    The Street Series kits are intended for cars that are mainly driven on the street and occasionally at the track. All Street Series clutch kits are designed with full face clutch linings bonded to a Marcel type disc to give you a smoother engagement than any puck style clutch. Full face clutches are available with the same friction materials as the puck style clutches and will not sacrifice torque.
    SS vs HD Kits:
    The SS series kits use the same friction materials on the disc but have an extreme clamp load pressure plate with a pedal effort increase up to 50%. The result is a more aggressive, stronger clutch that can handle most any performance upgrades.
    Rally Series: HD Stage 1 - 220 ft./lbs.
    Rally kits contain a modified high performance pressure plate and heavy duty organic disc. The linings on this disc are premium woven medium metal content lining. This facing has a 9000 RPM burst and dissipates heat quicker then any other organic lining on the market. This kit generates 1/3 more torque then stock. Also included in the kit are a throw-out bearing, pilot bearing, and alignment tool.
    TX Series: HD Stage 2 - 290 ft./lbs:.
    TZ kits contain a modified high performance pressure plate with a heavy duty Kevlar® lined disc. The metal backed Kevlar® linings provide a smooth engagement and have the torque capacity to handle high horse power, high revving engines; the disk is rated to 12,000rpm. These clutch kits maintain a stock feel at the pedal and have unmatched durability. Also included in the kit are a throw out bearing, pilot bearing, and alignment tool.
    OFE Series: HD Stage 3 - 300 ft./lbs:.
    The OFE kit combines the newest technology in linings: A Feramic full face lining on the flywheel side and a "Medium Metal" content Organic lining on the pressure plate side. This combination runs cooler and significantly extends clutch life. The OFE series clutch not only engages very smooth, it has the torque capacity of other Stage 4 clutch kits. This state of the art kit is what everybody wants when it comes to street performance.
    OFE Series: SS Stage 4 - 450 ft./lbs:.
    The OFE SS kit combines the newest technology in linings: A Feramic full face lining on the flywheel side and a "medium metal" content organic lining on the pressure plate side. This combination runs cooler and significantly extends clutch life. The OFE SS series clutch not only engages very smooth, it has the torque capacity of other Stage 5 clutch kits.
    FE Series: SS Stage 5 - 576 ft./lbs:.
    The FE SS series is the ultimate when it comes to delivering maximum torque to the street and strip driven car. With Feramic on both sides of the disc, the clutch delivers a more positive engagement. Because Feramic clutch material dissipates heat extremely fast it will give you maximum clutch life and a consistent feel each time you shift.
    Regular price:
    Stage 1 - $395 US
    Stage 2 - $425 US
    Stage 3 - $450 US
    Stage 4 - $585 US
    Stage 5 - $650 US
    GROUP BUY PRICE
    Stage 1 - $367 US
    Stage 2 - $395 US
    Stage 3 - $418 US
    Stage 4 - $544 US
    Stage 5 - $605 US
    Add a Steel Single Mass Flywheel to the order for an extra 365US!!
    Please send me a PM when you are ready to place your order
    May 04 2004
    00 BB S4
    York, Pa
    Re: *** 034 Ms - South Bend Clutch Group Buy ***
    Had OFE Stg 4 on the a4 and LOVED it so much I put one in the s4 2 months after I got it
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    How long is the GB good for???
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Feb 26 2006
    Earth
    Until we get 15 people on board.
