Results 1 to 26 of 26
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** 034 Ms - South Bend Clutch Group Buy ***
    GB IS NOW OVER - THANK YOU!
    034 Motorsport.com brings you another GREAT deal savings event.Just in time for election 2008 so that you can celebrate by buying your lovely A4 a new clutch set up.
    What better way to spend the next 4 years?
    Group Buy is being run for South Bend's HD STREET SERIES.If you want the Track Series simply send me a PM.
    Audi - A4 HD Street Series
    01A 5-speed & 01E 6-Speed
    THE SHORT:
    Stage 1 - 220 ft./lbs. of torque
    Stage 2 - 290 ft./lbs. of torque
    Stage 3 - 300 ft./lbs. of torque
    Stage 4 - 450 ft./lbs. of torque
    Stage 5 - 576 ft./lbs. of torque
    THE LONG:
    The Street Series kits are intended for cars that are mainly driven on the street and occasionally at the track. All Street Series clutch kits are designed with full face clutch linings bonded to a Marcel type disc to give you a smoother engagement than any puck style clutch. Full face clutches are available with the same friction materials as the puck style clutches and will not sacrifice torque.
    SS vs HD Kits:
    The SS series kits use the same friction materials on the disc but have an extreme clamp load pressure plate with a pedal effort increase up to 50%. The result is a more aggressive, stronger clutch that can handle most any performance upgrades.
    Rally Series: HD Stage 1 - 220 ft./lbs.
    Rally kits contain a modified high performance pressure plate and heavy duty organic disc. The linings on this disc are premium woven medium metal content lining. This facing has a 9000 RPM burst and dissipates heat quicker then any other organic lining on the market. This kit generates 1/3 more torque then stock. Also included in the kit are a throw-out bearing, pilot bearing, and alignment tool.
    TX Series: HD Stage 2 - 290 ft./lbs:.
    TZ kits contain a modified high performance pressure plate with a heavy duty Kevlar® lined disc. The metal backed Kevlar® linings provide a smooth engagement and have the torque capacity to handle high horse power, high revving engines; the disk is rated to 12,000rpm. These clutch kits maintain a stock feel at the pedal and have unmatched durability. Also included in the kit are a throw out bearing, pilot bearing, and alignment tool.
    OFE Series: HD Stage 3 - 300 ft./lbs:.
    The OFE kit combines the newest technology in linings: A Feramic full face lining on the flywheel side and a "Medium Metal" content Organic lining on the pressure plate side. This combination runs cooler and significantly extends clutch life. The OFE series clutch not only engages very smooth, it has the torque capacity of other Stage 4 clutch kits. This state of the art kit is what everybody wants when it comes to street performance.
    OFE Series: SS Stage 4 - 450 ft./lbs:.
    The OFE SS kit combines the newest technology in linings: A Feramic full face lining on the flywheel side and a "medium metal" content organic lining on the pressure plate side. This combination runs cooler and significantly extends clutch life. The OFE SS series clutch not only engages very smooth, it has the torque capacity of other Stage 5 clutch kits.
    FE Series: SS Stage 5 - 576 ft./lbs:.
    The FE SS series is the ultimate when it comes to delivering maximum torque to the street and strip driven car. With Feramic on both sides of the disc, the clutch delivers a more positive engagement. Because Feramic clutch material dissipates heat extremely fast it will give you maximum clutch life and a consistent feel each time you shift.
    Regular price:
    Stage 1 - $395 US
    Stage 2 - $425 US
    Stage 3 - $450 US
    Stage 4 - $585 US
    Stage 5 - $650 US
    Dec 19 2007
    York, PA
    Re: *** 034 Ms - South Bend Clutch Group Buy ***
    are you fucking serious? I just bought mine last week from DTH.
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    roughly how long will this group buy be open? till supplies run out?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    I assume this is just the clutch disc no other parts included? If not how much for a compleete clutch kit? Sage 3 that is.
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Does this include the resurfacing that SB normally does free?
    My 2004.5 APR Stage 3+ is SOLD
    Feb 26 2006
    Earth
    GB ends when we have 15 people on board.I think this is the first GB I am going to run where B5 guys are going to out take you...
    If you want a package deal simply send me a PM.
    Buncha motorcycles
    Memphis, TN
    arent those the same prices as normal? stage 5 @ $650?
    APR Stage 2/AWE Intake
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Quote Originally Posted by n7plus1 View Post
    I'm in the same boat. Bought my from jeff last thursday. Its not a huge savings but still.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Is this for the 1.8t only?? i will be needing a new clutch soon i think and might pull the trigger if i have excess funds.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Feb 26 2006
    Earth
    Quote Originally Posted by Papachristou View Post
    605
    Quote Originally Posted by IronAudi View Post
    Any Audi
    If you do not see it on the list simply send me a PM.
    The savings are not bottom dollar huge but they are enough to get a decent amount of interest from the public.We are not in business to "blow shit out the door" because it hurts us,South bend and in the end the customer....
    Before I became an advertiser,I was a user just like you and I remember days where I would buy a product for $X and then 2 weeks later it would be worth $X - 200US.Now suppose I did not want my product?How can I get back my initial investment.In short you cant...
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    Does this include resurfacing?
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Buncha motorcycles
    Memphis, TN
    does it include the following?
    resurface
    shipping
    paypal fees or do you take credit cards?
    May 24 2007
    Southern California
    im definitely going to have to jump on this. my clutch is currently out and I need a new one.......ill be getting back to you.
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 26 2006
    Earth
    resurface
    shipping
    We take credit cards
    Meet me on aim to organise payment : issamabed
    As for resurfacing the stock unit ,I will have to ask South bend although I do not recommend it (personally speaking of course)
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    why wouldnt you resurface it if you arent getting a new flywheel
    Feb 26 2006
    Earth
    Quote Originally Posted by trueno429 View Post
    Because I simply do not like the stock flywheel.
    Jul 30 2008
    Downtown Denver, CO
    Quote Originally Posted by Issam@034 View Post
    Resurfacing a flywheel rather than replacing it will save you alot of money however if you choose to go that route, alot of shops will void your parts and labor warranties. So if shit goes wrong early on, you have to pay for everything to get it fixed.
    -Matt
    FCDT Member #1
    Buncha motorcycles
    Memphis, TN
    lots of people have done it without any problems (including me) soutbend will tell you if your flywheel can be resurfaced or if it needs to be replaced and i think they would know a thing or two about clutches
    Feb 26 2006
    Earth
    Not saying you can not/should not do it.I have never been a fan of resurfacing flywheels.I guess thats me.
    Buncha motorcycles
    Memphis, TN
    true, why resurface for free (less shipping) when you can buy a new one from you!
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Haaa I was thinking the same thing... lots of folks have resurfaced successfully it all depends on ur performance goals (meaning wallet)
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 26 2006
    Earth
    If you want your flywheel resurfaced we can organise that.It is not an issue....
    My job is not to come on here and cram parts down your throat,I leave that for the other salesman....
    My job is to design ,innovate and introduce new products to the scene while giving advice based on my 10+ years of being with VW/Audi brand.You do not want my advice then simply do not take it.
    Buncha motorcycles
    Memphis, TN
    now thats funny sh!t.
    please do tell me what you have designed, innovated and introduced? HF IM is all i can think of...
    you are an 034 vendor and sell their products. this isnt "your" clutch that you designed and introduced is it?
    Ill stay with option b and not take it since i waited how long for my mounts? 1.5 months?
    by the time i add in your paypal fees, shipping and resurfacing ill bet mike, nick, tony or jeff will be cheaper
    i guess its just cause i had such poor service on motor mounts. a simple pack and ship item. i cant imagine having trouble with clutch kit from you
    Feb 26 2006
    Earth
    * Big turbo kit for Audi A4
    * Dry sump kit for VW/Audi application
    * Supercharger kit for MKII/MKIII VW
    * Intake manifold
    * Electric water pump kits for VW/Audi application
    * etc etc...
    let me know when you start doing any of the above and I will happily start making fun of you.
    Well then buy it from Nick,Tony & Jeff....there are some customers (like yourself) that you simply can not please.Poor service?You wanted a FULL refund because you did not get your mounts asap.There was a wait time involved with the mounts if they were out of stock.In your case the transmission mount was out of stock.I am sorry that you felt you were treated badly but I tried my best to deal with you in a diplomatic way.Your current reply is an exact example of what I dealt with in the PM's.
    On that note the Group Buy is officially over.Thanks for all who participated.
    Oct 29 2005
    10speed
    San Francisco, CA
    sorry you had shitty service with Issam, but hes one of the most informative guys on here... He will hook you up for sure. Many times, the 034 stuff isn't his fault, I have dealt with it first hand of issam having my order placed, and 034 not shipping it for weeks
    - Clint
    Buncha motorcycles
    Memphis, TN
    I have gotten great service from the above listed suppliers. I suppose when a customer Inquires about a product then orders the product and is not told they are out of stock for months so he asks for a refund and is refused then it's the customer who is impossible to please huh?
