Results 1 to 4 of 4
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    removing interior dressings?
    what's the rule of thumb for cleaning the dash/plastics in between dressings? Is it necessary? I think I'm noticing that layers of dressings build up over time as grime.
    If occasional cleaning IS a good idea, what products do you like?
    TIA!
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Re: removing interior dressings?
    First off, what kind of dressing are you using? If its silicone based...ie, amor all, or son of a gun...its bad all together. But if your content on using it, dont use it alot, in between application, just lightly damp a microfiber and wipe away. You dash shouldnt be 'dirty', but more or less dusty...unless your a dirty person! :)
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
    Nov 20 2007
    Toronto ON
    Quote Originally Posted by Twista616 View Post
    I use 1Z Cockpit Premium, and love the matte finish it leaves. And I do dust in between dressings with damp MF towels.
    But I guess I'm mostly curious about the eventual effects of always adding more, and never really removing anything. Can dressings really just disappear?
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    well, in a way, when you apply a new application, you aren't adding to it, your actually wiping away the old, while applying the new. To my knowledge, it will not build up unless its silcone based. Also, if you dust in between you are removing some of the material also...i wouldnt worry about it, especially with the 1Z, which is good stuff!
