Results 1 to 4 of 4
    Veteran Member Four Rings AudiBoy808's Avatar
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    What could be causing this problem..............
    Ok I can't seem to open my trunk. It's unlocked that I know. When I use the remote and unlock the doors all the doors unlock but not the trunk. Can anyone tell me what could be causing this.
    tia
    99.5 silver A4
    FI CF hood | Eurogear CF Euro trunk | Eibach Pro-St coil overs | Crimson K6 | Kerscher frnt | Avant garde sides | RSR Rear | Vibrant exhaust | Silver CF rear seat inserts |
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Re: What could be causing this problem..............
    Trunk Locking Cylinder is broken/bad. Time to replace it my friend.
    Check out the Bentley repair manual on how to replace it.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    Quote Originally Posted by belinko View Post
    Hey thanks man, do you happen to know if it's an expensive thing to fix.
    99.5 silver A4
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    try unlocking the trunk with the key. it has the valet feature where it wont open with all the doors and can only be opened by the master key as opposed to the valet key
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
