Results 1 to 15 of 15
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Anybody switch to the B7 Key and have battery/ programming issues?
    I switched to the B7 key and It is beautiful. I love everything about it but lately it has been pissing me off. It has been acting up like, I would drive somewhere, park, lock the car with the key, then when I would come back to the car it wouldn't unlock with the remote, only when I used the key in the door. Then I would drive home and it wouldn't lock, I would need to program the key to the car again (unlock, ignition on, ignition off, lock and it is programmed).
    I replaced the battery and there is no problems with the connection of the battery.
    Is there anything else I could try? Could the B7 Key Fob I bought be a faulty model?
    Anybody else have this problem?
    Thanks, Matt.
    2004 A4
    Central Jersey
    Re: Anybody switch to the B7 Key and have battery/ programming issues?
    BUMP
    Aug 26 2005
    Quote Originally Posted by 3.0L AUDI A4 View Post
    Thanks, Matt.
    Scan the Central Convienience Control Module for DTCs related to the remote locking functions. Post back the results of the scan.
    2004 A4
    Central Jersey
    Will do, Do you know the module #'s I am scanning?
    Sep 10 2008
    Lost in Norway...
    Got any links on a guide of what I need to do to use a B7 key?
    I only have 1 key for my car, and i deff. could need a spare one - and a B7 key as my main key - ohyeah! :D
    Aug 26 2005
    Yes, open the Group 46, Central Convienience, then check for fault codes in that controller. Save any codes to a text file, then clear the DTC memory and post up the codes recorded.
    2004 A4
    Central Jersey
    Here is what I logged tonight in #46.. Fault code= Key...
    Anything I can do? Sorry for the delay.
    Thanks, Matt.
    Friday,14,November,2008,23:21:54:21125
    VCDS Version: Release 805.1
    Data version: 20080823
    Address 46: Central Conv.
    Control Module Part Number: 8E0 959 433 BB
    Component and/or Version: Komfortgerát T7B 1411
    Software Coding: 11884
    Work Shop Code: WSC 63351
    Additional Info: 8E1959801 Tõrsteuer.FS BRM 0003
    Additional Info: 8E1959802E Tõrsteuer.BF BRM 0003
    Additional Info: 8E0959801A Tõrsteuer.HL BRM 0004
    Additional Info: 8E0959802A Tõrsteuer.HR BRM 0004
    1 Fault Found:
    00955 - Key 1
    35-00 - -
    2004 A4
    Central Jersey
    Update! I cleared the code, got out of the car, locked it. Left for 20 minutes. Went back to the car where the same exact problem occurred. I scanned for codes and the same exact code popped up. Cleared it again, and it popped up again... What should I do?
    2004 A4
    Central Jersey
    BUMP
    Aug 26 2005
    See linked info. http://wiki.ross-tech.com/index.php/00955
    2004 A4
    Central Jersey
    Ok that's the adaptation chart. I did that originally when I first programmed the key. I just did it again, seems to work good... I waited 1 hour and the key still worked. I then vagged the code 46 control module and it shows the same fault "key".
    Do you think this fault will go away after I drive around for a few days?
    If not, What should I do?
    2004 A4
    Central Jersey
    BUMP
    Aug 26 2005
    Is the code the exact same as the one before? If yes, then the possible causes must be checked and ruled out in turn, until it's fixed. If it's a different code, then the above still applies.
    2004 A4
    Central Jersey
    Yes same code as before.
    To fix the problem, I bought another B7 key and programmed that.. so it must have been the key that was faulty.
    I don't know exactly but the problem stopped.
    I have a "faulty" B7 key for sale if anybody wants one.... $10 LOL
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Interesting! It sounds like this was a transmitter problem and not an immo problem. Wonder what could be wring with the transmitter? Maybe it got wet or something like that.
