Results 1 to 7 of 7
    Senior Member Two Rings A4-Achtung's Avatar
    Oct 01 2008
    2.8 B5 A4 Quattro
    Austin, Texas - Third Coast
    3in Exhaust on a K03s
    Is 3in. exhaust too much for a K03s? I want to put a 3in. on for now so when I upgrade I wont have to change to much. Just wondering if I will have any issues mechanically. I plan on using a 3in vibrant resonator and a 3in vibrant muffler, and a 3in testpipe with a cel fouler plug.
    2001.5 B5 A4 QTM - AVIC F700BT Mod'd 3.0 - GIAC-X Tune - Bailey DV36 - 3 in. TestPipe 2.5'' Back- Blacked Out Everything - 6000k DDM HID Headlights And Fogs - Slotted and Drilled Rotors - HAIL DAMAGE!!! -
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: 3in Exhaust on a K03s
    I have 3" exhaust from my Downpipe back currently (using my K03s). No, it's not too much, yes, it's overkill.
    I would have used a 3" downpipe had it been available at the time, however I know now that it wouldn't help any more than the 2.5" Testpipe and downpipe do now.
    I got my whole exhaust for <$400, any more and I would not have wasted the money on more than a testpipe and downpipe.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    I had a 3" catdelet with a custom 3" full exhaust and a magnaflow muffler. Love the sound, a bit loud, but i didnt have to change exhaust after my BAT build, well only the downpipe since the turbo sits further up.
    No problems mechanically with the k03. you`ll be fine.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 30 2006
    B8 A4 Avant 6spd
    I wouldn't call it overkill. I have a 3" turbo back on my car, along with a 3" in/out magnaflow resonator and then a magnaflow muffler. It was too loud just with the muffler.
    -18 718 GTS
    Apr 14 2008
    a4 avant
    marlboro
    you guys are crazy i dont even run a 3" exhaust unless i have the cut out open
    -vrt-
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    A kid around here with an 800RWHP Supra runs a 3.5" exhaust. I think your back pressure will drop to zero.
    Apr 14 2008
    a4 avant
    marlboro
    im mean on a turbo car the bigger the better however, on a k03 any exhaust is honestly too big lol however i think 2.5 or 2.75 is the most you should go
    -vrt-
