Results 1 to 32 of 32
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Whats the difference between crossdrilled and slotted brakes?
    I'm looking at this kit from ecstuning.com
    Stage 2
    What is the difference in selecting rotors that are crossdrilled/slotted or just slotted. There is almost no difference in price. Is one better than the other?
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Whats the difference between crossdrilled and slotted brakes?
    Crossdrilled/slotted
    slotted
    IMO crossdrilled rotors have a tendency to crack.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    cross drilled rotors may be easier to crack.
    slotted rotors will give you more the hissing noise.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Mar 20 2006
    Quote Originally Posted by Maverick View Post
    Hissing noise. You mean when they overheat?
    May 03 2007
    german
    heaven/hell
    no, it's a constant noise that you hear while driving if you dont have music on loud enough.
    you will hear it when you put on the slotted rotors. sounds like something is always rubbing
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Like^^^ cross drilled tend to crack over slotted but thats under extreme conditions. If your just upgrading get the ones you like better.
    Mar 20 2006
    Alright, well I don't track the car or even beat on her. I guess I will go with slotted and drilled then.
    Thanks.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You should go with blank flat face rotors if you are using them for the street.
    You need all the metal you can get to help with heat dissipation.
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    I have the ECS stage 4s and don't get hardly any noise and rare squicking
    Dec 06 2007
    Quote Originally Posted by [email protected] View Post
    very true, also cross drilled/slotted will be harder on ur pads. Buddy of mine tracked his car once with Zimmerman's, and they were warped by the end.
    -Kirk
    BetaAlphaTau Member #58
    Mar 20 2006
    So you guys are saying not to worry about the crossdrilled/slotted, and just go with slotted?
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    they are saying get a flat surface ones....!
    Mar 20 2006
    Quote Originally Posted by EUROaleksey View Post
    Well, out of the options I gave them, all the rotors come with crossdrilled/slotted or slotted. Since a flat rotor isn't an option I assume they meant just slotted.
    But hey, thanks for contributing.
    Dec 06 2007
    get slotted/ cross drilled go all the way if those are ur choices. Heck i would.
    -Kirk
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by KPC1.8TQuat View Post
    I gave the best option that wasn't listed.
    If you have to chose from your options then go with slotted.
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    are you just using it for street? then it wont really matter... you wont stress them enough to crack, no need for slots, or cross drilling... e.g. it doesnt matter... the only factor here would be pad wear.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Slotted will result in faster pad wear (slots are designed to maintain a clean contact surface between the pad and the rotor). You only need cross drilled if you need to reduce weight and cool down the rotors faster.
    The downside of cross drilled rotors is the chance for heat stress cracks because the holes are literally drilled out of the rotor. Those who have it on cars that only get street use are only using it for show. Driving around on the streets doesn't build up the heat in the brakes to warrant any holes.
    More than likely, your rotors are mostly cool until needed for emergency. At that point, you need as much surface contact to generate as much friction as possible to bring the car to a stop. Like Winston said, the best street solution is a simple plain rotor with no slots and no cross drilled holes. The next step up would be slotted rotors (good if you do a lot of spirited driving and/or track time).
    USP CLUB MEMBER #34
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by MOFSTEEL View Post
    this is a popular myth. the first old time cross drilled rotors did have a tendancy to crack more because they werent drilled with the vanes. new cross drilled rotors are drilled in certain locations and are usually chamfered to to further reduce cracking.
    porsche, vettes, vipers, mercedes and lots of other high end cars and track cars come with drilled rotors from the factory. brembo sells cross drilled almost exclusively. why is that?
    APR Stage 2/AWE Intake
    Mar 20 2006
    So I guess I need to base my decision on the following...
    1) I don't track the car, and I usually drive pretty mellow.
    2) The reason for the upgrade is because I'm going GT71r elim.
    3) I can't go any bigger than ECS stage 2 because I use 17's for my winter wheels.
    Unless someone can recommend a good non-slotted BBK upgrade, then I am going with the ECS stage 2 slotted with porsche boxster 4 piston calipers.
    May 24 2007
    Southern California
    Quote Originally Posted by CyberPMG View Post
    listen to to him^^^
    its all for cooling. they would be overkill for street driving.
    Kyle
    2.0L Revo GTRS Eliminator
    Mar 20 2006
    So what rotors are you guys running?
    Buncha motorcycles
    Memphis, TN
    i got slotted/CD from ecs but i think next time or on a BBK i will just get slotted..... i got these for looks... had them for 45k of pretty tough driving and they havent cracked at all
    just switched to ferodo ds2500 pads and they are a huge improvement over hawks. when they sink in, they drag the car down very quick
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by Papachristou View Post
    Big difference between making a x-drilled rotor at the manufacturing level vs. taking a blank and drilling them afterwards.
    Guess which process ECS uses.
    Mar 20 2006
    Ok ok ok
    What kit would you guys recommend to clear OEM 17" S4 Avus rims?
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Ok ok ok
    i'd reccomend you use the search before posting stupid questions. why did you even post if you don't care what people say? x-drill are more prone to cracking. xdrilled, slotted, dimpled will wear your pads faster.
    you're not going to be on the track. use OEM, flat rotors. if you did a search, you'd realize changing your rotors WONT have an effect on your caliper clearance.
    Mar 20 2006
    Quote Originally Posted by ngng View Post
    I did use the search feature which pointed me to the different ECS brake setups.
    Good contribution to my thread, thanks.
    Mar 20 2006
    An example of a helpful post. Personal experience and recommendation.
    Thanks.
    Buncha motorcycles
    Memphis, TN
    Thanks.
    anytime. let me know if u need anything else
    Feb 23 2004
    Stow, OH
    A BBK that will fit inside a OEM 17" S4 Avus wheel is the Stoptech 332mm slotted rotor kit. I have this on my car and use those exact same wheels as my winter set.
    Since you've expressed more street use (I do track mine), your best solution would be to look into upgrading to some B6 S4 calipers and rotors. The rotor can be a plain rotor or slotted. Go with some good brake pads (Hawk HPS, Ferodo DS2500, etc.) and fresh brake fluid (needs to be flushed out completely every 2 years regardless of miles) with any DOT 4 compliant brand. For a little more, go with Motul 5.1 synthetic which is DOT 4 compliant and offers higher boiling points.
    USP CLUB MEMBER #34
    Dec 06 2007
    ^^precisely, for the street the most cost effective method is to do a B7 A4/B6 S4 brake upgrade they are the same. U need minimal stuff so not too costly and they'll work great. easy to change too.
    -Kirk
    Mar 20 2006
    Quote Originally Posted by AudiA4Turbo22 View Post
    Ok, cool. That is definitely something I will ponder this weekend before I make a BBK purchase.
    Sep 02 2005
    Montreal
    I could think of more cost effective ways of increasing unsprung weight with no real benefits.
