Thread: MBC Question
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    MBC Question
    Alright so my friend had a Forge MBC laying around his shop and I put it on. I put the REVO on boost 9 and took it out. I'm only getting 15psi out of it when its all the way open.. What's the deal? Do I have it installed wrong or something?
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: MBC Question
    do you have a boost gauge, can you pull more then 15lbs without it?
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Jul 11 2008
    Illinois
    Re: MBC Question
    Yeah I do. And yeah, with the n75, I get like 20psi.. But that's on boost 8 which should be like 22-23.
    Anthony
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Re: MBC Question
    did you try to tighten it down/hold the valve closed longer will do. or double check all connections it sounds like there is no boost going to the wastegate actuator. but the wastegate should open around 10 psi.
    if none of that works check your actuator rod for any play if there is then your n75 was able to adapt and keep your boost on where as the mbc is just a one way valve and is unable to compensate.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: MBC Question
    Quote Originally Posted by GTRS A4 View Post
    Is it leak type of valve?
