Results 1 to 3 of 3
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    checking stored codes or mil
    I have the ebay cable, now can I pull up codes or does it gotta be the real thing?
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: checking stored codes or mil
    You can pull and clear codes, you won't be able to datalog certain blocks though.
    Also, if it's a serious problem, the code will simply come back unless you actually fix the problem it's come up with.
    You will need an OLDER version of VAG-COM to use with the 'dumb' interface cable you get on eBay (Ross-tech's description, not mine). I believe it is version 3112 and available free to download from their website, www.ross-tech.com
    Good luck, but if you really want to use the program for what it was intended for, you should buy the license for $99 USD.
    Dec 07 2007
    99 b5 1.8tqm
    WV near Pittsburgh
    yea I just really needed to check them, as I was getting tired of going to autozone to get it checked. I do have that version, I can't bring anything up so at least I know it should work now. I have to mess with it some more. thanks.
