Results 1 to 9 of 9
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    umm car is dead at advanced
    I took out the battery since it's going bad put a new one in to the correct specs and now nothing car won't light up or anything. What could possibly have happened? Sitting at advanced now don't know what to do.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: umm car is dead at advanced
    did you install it right??? Make sure the battery yiou bought has juice, that or try to jump it see what happens idf yo can get any power to it.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Sep 27 2008
    Orlando, FL
    yep optima yellow d35 everything was tested after I took out the old battery I couldn't even get a spark
    Jun 13 2007
    Middletown, CT
    check your fuses, you may have burned one or 2 out. That or take out the battery again and let it sit and try that.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    (Just to make sure)
    Make sure you are plugging in negative-to-negative and poistive-to-positive
    I've done that mistake before
    -Sami-
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    (Just to make sure)
    +1. The 35 series has the label on in reverse in comparison to how our batteries should be mounted. Positive terminal should be on the right and negative on the left making the label upside down if you're looking at it from the front of the car.
    DG '02 A4 1.8TQM
    My Build Thread
    Established Member Two Rings b6quattro's Avatar
    Jul 08 2008
    '03 A4 1.8t Quattro 5sp
    Orlando, FL
    Which Advance?
    '03 A4 1.8tqm - Brilliant Black on Tan
    Apikol Snub
    S4 Rear Sway
    Cold Weather Package (perfect for FL!)
    Sirius Sat. Radio
    Sep 27 2008
    Orlando, FL
    AAA came to tow and started wiggling the distribution wire and it magically started again with the old battery so I'll do the new yellow top later tonight. What a morning :( it was the advance off kirkman and winter garden.
    Dec 06 2007
    kirkman? i have a street in my name? haha
    -Kirk
    BetaAlphaTau Member #58
