Results 1 to 12 of 12
Thread: booooosssstttt
    In Limbo Two Rings
    Jan 05 2008
    2002 audi A4,
    Jersey
    booooosssstttt
    got into a stupid argument about MBC and a stock b6 wats the most boost u can squezz safely out of our cars wit just intake and dv cuz this kid said u can do 14 but i said it would put u in limpp wats the safesst to crank upp
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Re: booooosssstttt
    you can do around 14-15 but u prob blow your turbo.. i blew mine like that.. i was told the car was tuned and wasnt and was trying to turn the boost up with that..turbo blew withing a few months...then went k04 and got it tuned... no mbc..runs great
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Re: booooosssstttt
    with a diode, lemmiwinks, and vag com you run 16-18psi!
    barrett
    2019 SQ5 Prestige
    Jun 13 2007
    Belmar,NJ
    Re: booooosssstttt
    yea thats basically like doing a basic tune on your car..but for a ton less money..
    Past cars:
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    Re: booooosssstttt
    My boost gauge spikes up to 17 pretty often and did really well for a while on the unitronics stage 1+ but now I ether have a leak or my DV is F'ed cuz i lost some psi and it doesn't spike as smooth. So i would say "safely" 14-15psi.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: booooosssstttt
    WOW iam getting old i can read the slang anymore
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: booooosssstttt
    Quote Originally Posted by PCYC View Post
    You must be getting old seeing that you cant type anymore either.
    Highest you can boost on stock chip is 300 mbar higher then what your stock ecu is requesting.
    diode+MBC is cheaper but doesn't make nearly as much power as a tuner chip. As for max boost the K03 can handle, I ran 26psi on a custom tuned street chip and 20psi on a custom tuned race chip.
    Feb 17 2005
    Sarasota, FL
    Re: booooosssstttt
    Stop being cheap and get the car flashed!
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Re: booooosssstttt
    why turn up the boost if u cant get the fuel to push it...thats why i dont beleive in boost controllers unless you are properly tuned for it...Get it flashed and have fun...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    Re: booooosssstttt
    I've been hitting 24 psi for 6 years now, depends on temperature, humidity and altitude. 22 psi is more relaible. a higher boost spike doesn't always equate to better numbers though . . . proper quality programming is important . . . get a chip/flash.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Apr 01 2007
    houston texas
    Re: booooosssstttt
    Quote Originally Posted by OneBadAudi View Post
    The vehicle has sensors and such in place so it can add fuel, to a certain extent. yes a chip will yield slightly more power, but not by much compared to a diode/lemmi combo.
    barrett
    2019 SQ5 Prestige
    Veteran Member Three Rings aalipio's Avatar
    Sep 03 2008
    05 S4 V8 02 A4 1.8T
    N las vegas
    Re: booooosssstttt
    Whats factory boost set at?!
    Also...
    If I go Giac software, what will I be set at as far as boost?!
    With a ss test pipe and everything else stock...
