    Mar 24 2008
    chicago
    1998 Audi A4 2.8L V6 Quattro Automatic 100k miles
    My battery recently died so I replaced it.
    I also replaced my spark plugs with Bosch spark plugs and OE wires but my Audi still vibrates on idle. What else could be causing this?
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    Re: 1998 Audi A4 2.8L V6 Quattro Automatic 100k miles
    injectors? or clogged fuel filter?
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    did you gap the plugs, even though they are new they might be incorrectly gapped or defective, any check engine light? plug wires on tight with electric grease on all terminals, clean air, fuel filter
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Mar 24 2008
    chicago
    the plugs are labeled do not gap. I had a CEL previously. It was a misfire but it seems to cleared it as i been driving a month without it. the air and fuel filters are fairly new also.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    check your drivetrain mounts
    {99.5 Avant}
