Results 1 to 6 of 6
Thread: hub size?
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    hub size?
    Hello, i need to buy hub centric rings to try to get rid of the vibrations when i go over 60mph. does anybody know the size of the inner and outer diameter so i can purchase the correct hub ring? i changed my wheels to aftermarket 19s. thanks for the help! :D
    Feb 15 2007
    Re: hub size?
    should be standard 135mm.... I only know of the RS4 having 150mm hub face
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Oct 24 2008
    nyc
    Re: hub size?
    excellent... thank you kindly sir!
    Registered User Two Rings john@fifteen52's Avatar
    May 02 2008
    B7 A4, Mk3.5 Cabrio, Mk5 Jetta
    White Plains, MD
    Re: hub size?
    Wait, if you're trying to order hub-centric rings, you need to know the size of the hub center not the hub face. The hub center is 57.1mm. As for the outer diameter of the rings, you need to either measure the hole in the wheel or contact the wheel manufacturer to find out the actual measurement. Don't just guess or get it close with a ruler, the measurement has to be exact for the rings to work.
    Your wheels should have come with hub-centric rings. Are you sure you don't have them on there? Check your wheel bolts too. Most aftermarket wheels use conical seat lug bolts instead of ball seat lug bolts.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: hub size?
    if you contact the vendor for your wheels, they should have an idea for what you need. they may not even charge much for them.
    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    Re: hub size?
    Inner diameter is 57.1mm, outer diameter depends on what the hub of the new wheel is.
