Results 1 to 30 of 30
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    So it seems with an SD I can actually record exterior Video....
    with the HDD it would stop recording, but not anymore <Cleek
    Oct 06 2004
    Minnesota
    Re: So it seems with an SD I can actually record exterior Video....
    YES! I love you videos. I need to make more myself
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    That's awesome!
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Ian your gay... What a tease you asshole
    Sep 24 2005
    always in design
    Quote Originally Posted by A4Rob View Post
    Thanks, yes yes yes you do need to make more videos Rob
    Quote Originally Posted by GetBoosted84 View Post
    That's awesome!
    I'm stoked the SD card alows me to record unlike the HD Video's galore coming soon....
    Quote Originally Posted by 317ssayzarc View Post
    I am an asshole So I went out and up against a STG3 B5 S4 PJ k04, which was running 102octane on Saturday. The same B5 S4 on Saturday killed (2) ASP kit cars, with one running GT28's and the other RS6 turbos. I don't feel bad, but I should have gone at this with 30psi instead of 27 and I should have had race gas myself. The outcomes would have been greatly different.
    Round 1 getting ass spanked at 22psi by Jackson's perfectly running PJ k04 B5 S4 on Saturday.....
    Round 2 at 25psi still getting really walked....
    Last pull at 27psi I fair much better, problem is area under the curve he had it and I didn't along with the other 2 B5 S4's running bigger turbo's than the PJ K04's. I'm planning on coming back and giving this anoher go before I change the hotside to a larger a/r and tuning a bit
    Jackson's PJk04 vs ASP B5S4 w/ gt28's round 1
    Jackson's PJk04 vs ASP B5S4 w/ gt28's round 2
    Jackson's PJk04 vs ASP B5S4 w/ RS6 turbos
    Oct 06 2004
    Minnesota
    Nice vids again
    Instagram r_michals
    Jan 25 2006
    A4 2.0T
    MD
    Great videos Ian, but Jesus -- that S4 killed you man.
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    yeah.... even on c16 and 30psi he'd still walk you. should have started from a higher rpm and brake boosted at least.
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Nice vids. Yeah the hard drive camera's just cant handle being bounced around which is why I stopped trying to record my runs from inside the car since all it would do is shut off on the launch.
    Sep 24 2005
    always in design
    Quote Originally Posted by Don Supreme View Post
    Take a look at all the video's Jackson has up, he lives for this. I brought a knife to a gun fight so to say. Jackson killed a setup very similar to GURU's on Saturday also, keep that in mind:)
    Quote Originally Posted by bernB5 View Post
    The area under the curve the B5 S4 with PJ k04's has is more than we can have in most cases. Keep in mind Bern that the last pull I improved dramatically and with the obvious which you mentioned in conjunction with 104 or higher I think the results will vary a bit, not saying I can walk Jackson but I think I may hold my own much better then.
    Thanks Mike, I don't know why I waited so long to try an SD card in the same camera, but I did and just found out by recording on the SD you have no issue with vibration. You should try an SD card in your camera and see if you get the same results.
    Oct 27 2007
    In the lab
    Thats cool and all Ian, but I really wanted to see you hitting some turn ins, apexes, and turn outs!
    Jul 07 2004
    socal
    Quote Originally Posted by bassed View Post
    I will have to give that a try on my next trip to the track which should be in a few weeks, time to crank the boost up.
    Sep 24 2005
    always in design
    I plan to make a nice little compilation and lace some chunes and text as well this weekend, I'll do it just for you
    It is at this point I encourage all to get off their lazy arses and not leave me standing as one of the few people on here making videos and doing runs
    Another angle on the last pull against Jackson from my car.
    Jul 07 2004
    socal
    I will try to do some vids at the IDRC event in a few weeks. Now I just have to find that damn camera.
    Sep 17 2006
    07 cbr600
    Exterior vids look good, nice and sturdy. Did you use a "sticky pod"?
    Sep 24 2005
    always in design
    Quote Originally Posted by Russell2686 View Post
    Nope, not the "sticky pod," but one much stronger
    Only buy video mounts and such through FILMTOOLS.com
    Jan 25 2006
    A4 2.0T
    MD
    Whats the deal though? Why is his 'ish so fast? Are you sure he has plain jane ko4s? No spray? That thing just moves out............ Like he making 500whp (not happening with pj ko4s) and you were making 320...
    I really hope you are not starting races from anywhere below 5200RPM --
    Sep 24 2005
    always in design
    He's one of the most well known PJ K04 setups on the other forum and the WO B5S4 forums. He had 102octane, no spray. Unfortuntley the dig was from 3500ish in 3rd, so I had lag and he didn't. His car is the epitomy of perfectly running PJK04 and has been for years. I have no idea what I am making though. My DYNO numbers were from 18psi only, I have no clue what happens above that. I can BUTT dyno this weekend and see where I stand I guess. I need to do a leakdown and compression test as well.
    Jan 25 2006
    A4 2.0T
    MD
    Shoot, if I started @ 3500 a pinto would put cars on me.........not exactly, but you get my point.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    im sorry man, i really don't mean to pick on you or play devils advocate. but those ASP cars are a JOKE. everyone on the s4 boards(AW too) knows this. Guru's setup is FAAAAAAAAR beyond any GT car ASP has put out other than Eurocodes.
    but don't feel bad about being spanked by Jackson's avant. he has one of the top 10 best running k04 cars.
    but running an actual WELL setup GT S4, you would get your ass handed to you. and so would jackson
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 25 2006
    A4 2.0T
    MD
    Has Jackson dynoed or run in the 1/4?
    Jul 07 2004
    socal
    Well we already know what a great running cutom tuned K04 S4 can do, just look at the times Jason from JHM puts down. I have yet to see another GT S4 run 10's.
    Sep 17 2006
    SLC, UT
    i don't think so. or at least in a long while.
    but he has other vids of him hanging from a roll with cars that have run mid 11's in the mid 120's for trap.
    that's nycvr6's and 10secs4's silver car. i'll look for the vid real quick
    Current:
    Previous:
    Jan 25 2006
    A4 2.0T
    MD
    Does he have all the stuff JHM's car has? RS4 mani/heads, etc, etc..
    Oct 29 2005
    10speed
    San Francisco, CA
    nah man PJ K04... Sean hes cool as shit, he works like 10 minutes from my house... I talked to him for a bit here and there... Ill probably do some pulls with him when my setup is done
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    is this jersey mexico...or pa,mexico i want in on the action lol and its not too far away
    -vrt-
    Registered Member Two Rings Oranoco's Avatar
    Oct 14 2008
    Audi A4, Escort RS Turbo
    United Kingdom
    I need to get out and shoot some more car clips. Unfortunately by time I'm done at work it's dark so no fun to be had. Might have a play at the weekend though
    1996 Audi A4 1.8T @181bhp, 199lb/ft.... so far!
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Well thats my 49th reason to by an S4!!!!!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Sep 24 2005
    always in design
    Quote Originally Posted by 1fstavant View Post
    It's Mexico that's all I am saying. PM me if you want in or get daring and lurk on other forums and you will find a lot more is happening around you:)
    Apr 10 2007
    Eastern PA
    Forget the butt dyno. We can use my g-tech pro comp meter and that will tell you your approx. numbers.
