Results 1 to 18 of 18
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    MIKA Software Tuning?
    Does anyone know someone who can mess with the MIKA software from ATP? I had it on my car but it ran rich so I took it off and put on the APR software.
    Oct 06 2004
    Minnesota
    Re: MIKA Software Tuning?
    Mika= kaboom
    Search the archives here and you will find out that most people will just tell you to buy something different.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    yea, theres lots of bad mika stories going around
    you have aeb engine code?
    contact via email please.
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by k0mpresd View Post
    Yes. I know that MIKA = KABOOM but I dont have the money to spend on new software. Plus someone told me that theres a way to fiddle with it to make it run better. So was wondering if anybody knows anyone to has done this?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    i have mike on my girls car, dont plan to change it anytime soon since the car came with that software. I want to know this as well.
    BTW, i tried to vagcom it and the program cant get into the ECU?, i took it to autozone or discount auto parts to have it scanned for codes and their little computer didnt work either, a local member tried with his vagcom and still no luck. anybody know anything about this?
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Established Member Two Rings VTECCURED's Avatar
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    Quote Originally Posted by pipe7284 View Post
    first.. i would check your fuses...
    I lost communication with the ecu one point when i tried to extend the obd2 connector on my passat... i cut the obd2 connector cables without killling power to the ecu and i popped a fuse...
    so check your fuses!
    BOOSTFACTORY.NET
    Sep 14 2006
    Lansing, MI
    ^^^^i will check the fuses this weekend. thanks
    SOLD
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    or if you have aftermarket radio disconnect that and check again...
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    and if you have a stock radio its prally the fuse in the back of it
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Three Rings oface's Avatar
    Apr 23 2004
    '99 A4 1.8TQM, '99 RMK 700
    Fairbanks, Alaska
    Quote Originally Posted by 20vpower View Post
    This same exact thing happened to my car after putting in a new battery in. Would a blown fuse behind the radio, for the OdB2 and radio cause limp mode?
    Pipe, how does the car run right now? are you gonna vag it because it's on the fritz?
    BetaAlphaTau Member # 51
    Sep 14 2006
    Lansing, MI
    I have stock radio, i will check the fuse behinde the radio. I checked all other fuses and are ok. so i`ll check that other one behind the radio.
    Oface: car runs great, i havent had any issues with it, except that i cannot get it to vagcom. But that will be taken care of. I am running mika tuning with 440cc greentops and it runs fine. I was a little behind, about a fender, from an STI when i raced him the other day. I pulls strong.
    SOLD
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    theres an obdII fuse, other than that, idk maybe the radio fuse but the radio wouldnt work if that was out.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    bump
    99.5 A4 1.8 TQM
    Eliminator GT2871R, UNITRONIC "440cc" tune, FMIC, 2.5" exhaust, SB Stg 4, Gutted LaBree, B&M short shifter, 034 Snub Mount, AWE DTS, LLTEK FR Strut Bar, Synapse DV, SCAT Rods, 034 HF Exhaust Manifold
    Registered Member Two Rings a4speed's Avatar
    Sep 27 2007
    Orem, UT
    download unisettings and you can make some adjustments.
    info:
    http://www.audifreaks.com/showthread.php?t=197
    Dave's 2001 Audi A4 1.8TQM
    l Hybrid K04 l GIAC l 034 l Techtonics l 5 Bar FPR l Carbonio l Forge l Evoheatshield l Southbend l
    My Other Home: www.audifreaks.com
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by a4speed View Post
    info:
    fyi it doesnt work on ndbw cars
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    info:
    Thankx but I am no tuner so what would you suggest for a high pressure/ running rich? If I were to use UNisettings.
    Quote Originally Posted by AudiRacerS4 View Post
    This may seem like a dumb question but ndbw is where the throttle is controlle by the ecu, whereas mine being an AEB is controlled by a cable connected to the gas pedel correct.
    99.5 A4 1.8 TQM
    Oct 28 2006
    Quote Originally Posted by Fink_tha_Audi View Post
    AEB engine is ndbw (non drive by wire) which means it has a throttle cable. Unisettings and Lemiwinks does not work on our cars.
