Results 1 to 8 of 8
    Registered Member One Ring himynameissteve's Avatar
    Oct 24 2008
    Audi A4 1.8t Quattro
    Rhode Island
    Unhappy Cylinder 3 misfire
    i have a cylinder 3 mis-fire on my 97 audi a4 1.8t im not sure whether or not its the coil packs or the mas airflow sensor..i changed the spark plugs and nothing changed the car is still sputtering and the check engine light is still on...any input or suggestions?
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Re: Cylinder 3 misfire
    99.9 % sure its ICM or Coil packs... a
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    what he said. Swap the coil pack from #3 onto #1 and see if the misfire moves to cylinder #1. The likelihood of it being a faulty injector are slim, and the MAF shouldn't cause a misfire on only 1 cylinder.
    If I were to diagnose it in person the first thing I would test would be the coil.
    Dec 05 2007
    Swap ignition coils from cylinder 2 and 3. If the misfire moves to cylinder 2, then replace that coil.
    Edit: djwimbo beat me to it.
    Jan 22 2007
    NNJ
    i should mention I now have a new misfire on cylinder 3. Just replaced both ICM and coil on cyl 3! so i am the .01% i mentioned. But I have replaced like 10 coils and 3 ICM's since owning B5 A4's.
    2012 Cayman S Track
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by firstarsbrnwhit View Post
    well, time to start checking the other things.
    Compression check would be a good thing to get out of the way, not that I would think that's the issue, you just want to eliminate it.
    Second, make sure the injector is firing.
    There is always the possibility that there's a wiring issue between the ICM and the coil itself (seen that happen too). Otherwise pull the plug out, put it in the coil and plug the coil in. If you lay the plug on the valve cover you should be able to see if it's arcing. I've seen a lot of people crack the porcelain on new plug installs and end up with the same problem they started with.
    Jan 22 2007
    NNJ
    I wasn't clear about my situation. I had severe multiple misfires which I fixed by changing the ICM. A few months later I had cyl. 3 misfire and changed the coil which fixed the problem. Now I'm having another misfire. Just wanted to clarify this was three different accounts, not failed solutions to one. Don't wanna thread jack (although im sure coil or icm and this guy will be golden) just scanned it tonight and haven't sorted it out. Thanks for the tips though.
    2012 Cayman S Track
    Oct 24 2008
    Rhode Island
    thanks for the help im going to trying switching my coils and eliminate that problem today and ill also run a quick compression check aswell. thanks for the help.
