Hi guys, We've had these guys in stock and ready to go for a while now, and I know this is a small forum, but I figured I'd make you guys aware of the option. The big turbo 1.8t guys are absolutely loving these....
This is a high quality, Canadian made intake manifold from our friends at SEM Motorsports. It was completely computer designed and optimized, with runner lengths and sizes chosen specifically for the typical big turbo user. However, the manifolds are making more power and torque all the way across the board, as well as spooling the turbo faster. This piece really is a win-win:
This second graph is a plot of the gains in both torque and horsepower across the rpm band. It also has the "gain" in boost level plotted (approx 0) so you can see that the same boost levels were used...
Now that we've established that these are in fact the business, some specifics:
- Cast in Canada from A356-T6 Aluminum and Heat trated
- 3/16" Thick Wall Construction for strength and reliability
- Large 2.75L Plenum for increased flow capacity and mixumum cylinder filling
- Computer designed tapered plenum for equal flow distribution and excellent transient boost response.
- Low profile design gives lots of hood clearance even in mk1's and mk2's.
- Integrated V-Stacks induce maximum flow velocity
- Large ID and Calculated Runner Length to support peak HP
- Fuel injector bungs are designed and located to facilitate optimal port runner flow and optimal fuel atomization.
- Bracket Mount Bosses for under-intake bracket assembly.
- Vacuum Port Bosses and IAT Boss are all located beneath the manifold for a more clean aesthetic look.
- Underside Vacuum Port drilled and tapped for supplied Brass NPT Fittings
- These are actually IN STOCK at our Salt Lake City location so unlike other companies you will not be left high and dry looking for your parts!
We also sweeten the deal in several ways:
- Supplied with FREE manifold hardware (IE Exclusive)
- Supplied with FREE OEM (60mm) or Cometic (80mm) Throttle Gasket
- Supplied with FREE OEM manifold to head gasket.
- FREE Fedex Ground shipping in the Lower 48, discounted worldwide.
We guarantee you will not find this manifold for a better price anywhere!
Visit our web page for more information!
Please direct questions via email to [email protected] for fastest response.
