Results 1 to 2 of 2
    Registered Member One Ring himynameissteve's Avatar
    Oct 24 2008
    Audi A4 1.8t Quattro
    Rhode Island
    Unhappy Cylinder 3 Misfire
    i have a cylinder 3 mis-fire im not sure sure whether or not its the coil packs or the mas airflow sensor..i changed the spark plugs and nothing changed the car is still sputtering and the check engine light is still on...any input or suggestions?
    Oct 31 2005
    Ashburn
    Re: Cylinder 3 Misfire
    Quote Originally Posted by himynameissteve View Post
    Do you have an S4? This is the S4 forum.
    Either way try swapping your cyl.3 coil with another one and see if the misfire follows, if so you know it's a coil pack issue. If not did you VAG the car for other codes. Plus you said it's sputtering i would also do a pressure test to check for boost leaks.
    - Instagram: @Sinister_rs5-
