Results 1 to 3 of 3
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Buying wheels, just some questions
    Hey guys... first time in this area of AZ, hoping some of you can help me out.
    I have a 2001 S4, stock rims on it now with 10mm spacers all around.
    I'm going to be buying some 18x8 Flik Hornets ( got a good deal, real good) with tires. Did a ltitle research and saw that the S4's stockers have an offset of 35, and so do the Hornets.
    Is this true?
    Will I still be able to run the 10mm spacers? or would i be better off with some smaller spacers?
    I'll probably need conical seated lugnuts right?
    Thanks a lot guys!
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Established Member Two Rings dantheman762's Avatar
    Nov 08 2007
    Re: Buying wheels, just some questions
    Pop the center-cap off of your stock S4 wheels and read the number beside the letters "ET"... I'm pretty sure you'll find that it will say 45. I'm running the same set-up with spacers to give that 35mm off-set look. Your new Fliks won't need the spacers (in fact if you use them, you'll probably rub the fenders), so you'll need to use the stock length lug bolts.
    The left lane is for PASSING!
    2016 RS7; Sepang Blue, B&O, carbon optics, TSW Bathurst 21x9, VCDS lowered
    2020 Toyota Tundra; TRD Off-Road, Crewmax, Premium Package (wife's vehicle)
    2006 Yamaha R6; full Yoshimura exhaust, Moore Mafia tuned.
    2019 Yamaha YZ250F; SSS full suspension revalve, No Toil SuperFlow airbox & filters, Cycra PowerFlow plastic, TP connected response map.
    B8 S4; Stage 1... Gone
    2010 Subaru STi; Stage 1... Gone
    B5 A4... Gone
    Jul 07 2007
    Tempe, AZ
    ok sweet. i'll order some up from ECS in conical seat form then.
