So today I started the conversion of my 99.5 interior to double din for new avic I just bought. Bought whole center console from volks88 (great seller) out of an 00 s4.
Got the navigation just at the right time. Pioneer has just released the 2.0 update which I have read improves the unit quite a bit.
The HVAC unit buttons must have had coke spilled on them or something being almost all the buttons were sticky (knew this before purchasing) Easy fix. Take the unit apart, take the faceplate off of the circuit board and run hot water through the faceplate. It is all plastic so I didn't have to worry about getting any electronics wet. With the faceplate off it was also a good time to clean the LCD screen from all the crud that had caked up over the years. Lighter fluid helped quite a bit.
I then ran under a shower head while moving the buttons in and out. Also did emerged in hot water untill all the buttons could push easily. A few minutes later I had a perfectly working HVAC unit. At the shop tonight managed to get the whole center console out and a good amount of wiring done. I need a cage out of a 00-01 a4/s4 to start installing everything. Metra kit is also coming in tomorrow.
Onto the pics.... (iphone ) Glamour shots once completed.
console carnage
and going in is....
