Results 1 to 6 of 6
Thread: AFR Ratios
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    AFR Ratios
    Ok i have a glow shift AFR guage fitted, it splices into the narrow band Lambda sensor. At WOT it drops below 10:1 and on coast in gear its 17:1.
    Under normal driving it flickes between 10 and approx 13.5, then as soon as i go WOT it drops to the floor. I know that the guage isnt calibrated but surely it cannot be that far out. I bought it as a way of keeping an eye on the AFR to keep the EGTs acceptable, i realise that the low AFR will the EGT down, but at the expense of fuel economy and performance.
    The only change since being mapped is the exhaust manifold and FMIC neither of which should have an impact i can think of. So anyone have any ideas?
    Is it down to tuning or do i have a faulty componant somewhere?
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: AFR Ratios
    narrrow band AFR gauges are worthless and are not designed to work with a turbo car, they were meant for NA cars. Basically you just have a disco ball in your car now.
    Jan 20 2005
    99 AJL TQS
    UK
    Re: AFR Ratios
    AHHHHHHHH!!!!! That i didnt know !!! so i would need a wide band with an additional o2 sensor bung welded in?
    So what shall i log to make sure the afr is good on VAG mike?
    -Mark -
    Jul 07 2004
    socal
    Re: AFR Ratios
    yes you want a wide band setup. For vag you want to log block 031.
    Jan 20 2005
    99 AJL TQS
    UK
    Re: AFR Ratios
    whats in block 31 as i have a DBC Aeb and i dont think i can access any blocks past 30 from memory. Its prob a damn euro thing
    -Mark -
    Jul 07 2004
    socal
    Re: AFR Ratios
    Quote Originally Posted by Mawhitey View Post
    Block 031 is 02 sensor readings. If you cant see any blocks after 30 you most likely have a shareware version of the rosstech software.
