Results 1 to 6 of 6
Thread: fuel pump?
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    fuel pump?
    Okay my car kinda sputters while in sitting idle right. Now when my fuel level gets to the red mark the car sputters real bad and also recently when i try to turn the car over while the fuel level is low the car wont start and only when the fuel level is low. i have to hold the gas down so the car will start. Could this be fuelpump going bad? help please
    Joooe Mamma!
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: fuel pump?
    Maybe, might start with a fuel filter first... it's alot cheaper.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Mar 20 2008
    south
    Re: fuel pump?
    ive done the fuel filter ive actually done just about everything u can do without totaling changing the engine.
    Joooe Mamma!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: fuel pump?
    have you done the pump?
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: fuel pump?
    Pull the pump out and clean the pick-up. See if that makes things better.
    If the problem persists then get a new pump.
    fuel pump DIY: http://a4mods.com/index.php?page=web.../fuelpump.html
    -Doug
    Mar 20 2008
    south
    Re: fuel pump?
    gracias ill do that and let u know how things go. appreciate the helpful info
    Joooe Mamma!
