can anyone enlighten me on what the follow fault code means?
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8E0 909 518 BC
Component and/or Version: 1.8L R4/5VT G 0010
Software Coding: 0016711
Work Shop Code: WSC 06335
1 Fault Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 008 - Implausible Signal - Intermittent
I've also noticed that I'm about 1 - 2 psi off what I usually run.
TIA
