Results 1 to 2 of 2
    Veteran Member Two Rings 0000_a4's Avatar
    Aug 03 2004
    Chi-Town
    Found oil in the IC Pipes
    I replaced my N75 valve and one of my intercooler hose last Saturday and found some oil in the IC pipes. I did some research and found some "could be" symptoms so I am not sure which one is causing the issue. Also, I noticed that the car is burning oil when left idle. Btw, my K04 turbo has about 40K miles.
    Here are the symptoms that could be the problem that I found:
    1.PCV Valve
    2.Plugged or clogged breather
    3.Blown or worn turbo
    4.Oil control rings could be clogged
    5.Turbo seal
    I am leaning towards #1 or #3. Also, can anyone tell me where #1 and #2 is located?
    Let me know what your suggestions are.
    TIA
    K04|Custom FMIC|310cc Injector|GIAC PC-16|APR Inlet Hose|2.5" Scorpion Exhaust Turboback|EVO MS DV|South Bend Stg II Clutch|Unorthodox LFW|18" BBS CH|RS4 Look Front|S4 Rear and Side skirts|Koni Coilovers|A.W.E. Drive Train Stabilizer| 6000k 50w HIDs|Valeo 1 piece Headlights| Stratosphere SS
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: Found oil in the IC Pipes
    #1 is a black hockey puck looking valve, plumbed into ur TIP. It can be found along the left top side of the engine. I doubt that is your issue if you found enough oil to be alarmed, because I have been running without one for a while now and didn't notice much oil in my IC piping. I don't know which "breather" you're talking about, but follow the T hose of the back of the engine (one direction actually leads to the PCV valve) and make sure it's not kinked or bent or torn.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
