    Established Member Two Rings will665's Avatar
    Oct 20 2008
    2003 A4 3.0
    Louisville
    gas filling issue...help
    03 a4 3.0...got this car about 3 weeks ago and when I first got it I could fill up my tank completly and the nozzle would not click off until it was full...the last time I filled up it clicked off early and only filled about 3/4 of the tank. I tried turning it on to relieve pressure and the same thing happend even after I drove to a different station. Does anyone have any idea what may be going on here...thanks
    2003 AUDI A4 3.0 Premium, Sport, CW Pckg.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: gas filling issue...help
    yup, happened once, didn't happen again.
    it could be a few things. the pump itself (which was my case i believe), the vapor return system could be clogged (charcoal filter), or the return system isn't opening when you insert the pump.
    if it's the filter that can be replaced, the flap for the return system not opening looked to be a full tank replacement from what i found.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Are you sure that the tank isn't full but the gauge is off? Incorrect readings on the gas gauge has happened to a lot of people - can't remember the cause/fix, but I remember reading lots of posts about it.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    I've had this happen just a couple of times before. Quick on-the-spot fix is to use the pump nozzle to keep the tank flap open for a bit while the pressure is relieved. You should hear the sound of fumes hissing out of it. This is probably just a temporary fix to a bigger problem but it's worked for me the few times i've needed it to.
    -Matt
    FCDT Member #1
    Senior Member Two Rings fcamargo6thave's Avatar
    Apr 08 2007
    The same thing happenned to me yesturday... I lent my car to my girls mom and she said that the gas attendant had problems filling the gas tank because it was leaking... She called me and i was pissed came home took it the gas station it was fine... I have a feeling it might have something to do with he weather
