Originally Posted by
317ssayzarc
Damn Sean... My car will be slow then... Ill be on weaker cams, lower geared tranny, less timing, ect... Boooo, gotta get my ish done and dyno tuned
Why do you say that? That video is ~19.5 - 20 psi......... My wastegate is absolutely FUCKED UP in that video. I spent a good bit of yesterday pulling of my 44mm, disassembling it and fixing the issues that made it almost come a part. The valve was basically open the whole time in those pulls (way before even hitting full boost, cracked open the whole time). I also have another major issue, but thats being rectified pretty soon.
So to recap.
You have a super sweet, ported AEB head
really strong mid range cams
standalone with 1000cc injectors
25 psi --- I think you will be doing JUST FINE!
But hold up, you have a 2.8 trans??? I hope not, because then you will definitely get RAPED!
