Results 1 to 9 of 9
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Upgraded to Xenons, drivers headlight is much more dim than the other.
    My car had halogens from the factory. I just bought a xenon kit (bulbs, ballasts, and all).
    I don't know if its a wiring thing or if one of my ballasts are crap. The passenger side headlight is much more clear and brighter than the drivers side.
    Thoughts? Suggestions?
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    Re: Upgraded to Xenons, drivers headlight is much more dim than the other.
    Just out of curiosity are you using the stock Halogen housing??
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    I have factory hid's and i have the same problem. Passenger side is way brighter. It may be due to the fact that the previous owner was in an accident and damaged the front right side. My right headlight might have been replaced with a newer unit with better optics.
    Any one know if there is a difference in optics through out the years? My drivers side is origional (2002) and the passenger side looks like it might have been replaced with a newer one.
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    if it is an aftermarket HID kit it is probably a faulty bulb/ballast/wiring.
    Oct 11 2005
    Post Falls, ID
    Quote Originally Posted by Audituning02 View Post
    Yes I am.
    Quote Originally Posted by pyro View Post
    Yes, I'm hoping its the ballast, they are cheap... well so are the bulbs, I am going to switch everything backwards when I get a chance.
    -Ricky
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    If all checks out okay, its most likely the bulb.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Oct 11 2005
    Post Falls, ID
    Thanks.
    -Ricky
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    I'm not sure how much brighter your pass. side is compared to the driver's side. but if I recall correctly, the porjector on the pass. side is developed to let a little more light out so we can see the "further" side of the road.
    TEAM|AXION
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    maybe its the way your looking at it?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
