Results 1 to 6 of 6
    Dec 28 2005
    NY/NJ
    Power Steering Fluid??
    I noticed this morning that the car had a whining noise up front while idle. Also, the whining noise became more distinct when turning the wheel left or right. Does this mean that i'm low on power steering fluid? If that's the case, is there a preferred power steering fluid to purchase?
    Thanks guys!
    Current: 2024 SQ7, 2021 RS5
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: Power Steering Fluid??
    Easy to figure out - check the power steering fluid level ;)
    Mine was extremely low recently when I checked it. I've used CHF and I believe that is Audi recommended (someone correct me if I'm wrong)
    Oct 03 2007
    B7 S4, Kia Cadenza, Kia Optima
    Orange County, CA
    Just go to the dealership, they usually will top it off at no charge. Keep in mind it's a mineral oil based fluid that can not be bought at autozone, pepboys, etc...
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Quote Originally Posted by wkornfeld View Post
    Exactly! Don't go fill it with any ole' fluid,must be mineral based..go to the dealership
    Dec 28 2005
    NY/NJ
    Okay will do.. thanks fellas
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    yeah i had the same problem a few months back... it was really really low... caught it before it started wining... i just topped it off
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
