Results 1 to 4 of 4
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Bosch to Hitachi conversion.... A bot to M box coding help
    I am doing a Hitachi conversion on my car and cant find solid information on what I should change the instrument cluster to. I am going from an A box 6spd to a M box. Maybe someone that has done this can shed some light into this. I searched but am unsure of the results I receives and would like some "for sure" answers.
    So, to restate the conversion is from A box to M box software. Also, I will be getting the maf and wiring kit from vast. I just need to know the right code to use in this scenario.
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Re: Bosch to Hitachi conversion.... A bot to M box coding help
    Feb 22 2007
    Earth
    yes, but I understood correctly that guy is going from an m box to an a box.... I am doing the exact opposite...
    Apr 27 2004
    Pacific NW
    you can code the ECU accordingly, from A to M or M to A. It all depends on what value you enter.
    Cluster recode : http://s4wiki.com/wiki/Cluster_recode
    Engine recode: http://s4wiki.com/wiki/Engine_recode
    You will need to do cluster recode for sure and maybe the engine recode as well.
