hey guys so today i partcipated in the black forest run meet. It was a blast and i was the only audi there (some of you guys should have came :P) anyways... i am having some concerns/ issues with the S. Its a Tiptronic and im wondering if maybe im just worrying to much so here it goes...
Problem #1: I have a giac x ecu on pump performance and if im just cruising along the highway and punch the gas (to kick down mode) my boost seems to go to about (14-16) PSI and then when it shifts it spikes to 17-18 and then back down 12-13 and then back up to 14-16 PSI again. Also i noticed when i was in tip mode and shifting manually the boost would be around 14-15 and when i shift spike up to 17 then go back to 14-15 again. Do i possibly have a boost leak/ problems with boost??? Or is this just normal??
Problem #2: I was trying to take the S to 160MPH today and when i have the giac ecu on Pump performance mode and im going about 135 getting ready to manually shift into 5th gear the tranny gets stuck between 4th and 5th and would downshift and upshift like 5-6 times until i ease off the gas a bit and then it would shift into 5th and then i can continue going just not flooring the car. Is this normal??
