Results 1 to 36 of 36
    Registered Member Two Rings
    Jun 07 2007
    Ontario, Canada
    Piggy Pipe Questions
    Hi all,
    Piggy Pipe questions...
    I am going to make my own piggies, anyone know if it would help if one wet down the inside of the pre cat prior to drilling and chizzeling out the filter material prior to battle. Do you think i'd be easier or at least less dust. From what i read it is a very dusty job.
    Second once all piggied, if i use the VAST CEL eliminators on the latest set of O2 sensors on the system??? will that help me "not" get cel codes???
    I know i need to be careful that nothing gets down to the cats.
    I have access to hammer drills with long drill bits.
    thanks!
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    Re: Piggy Pipe Questions
    I guess you could wet it down, but I just sucked it up got a mask and went to town with my drill. I have a CEL eliminator kit more of a DIY from napa and never have a problem with my post o2's. just take your time and make sure you read up on it first, and get someone that knows how to weld in your new o2 bungs.
    2000 s4
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I did a DIY for doing your own piggies:
    http://www.audizine.com/forum/showth...ate+diy+piggie
    I did not wet down the insides down. I didnt think it needed it. But I would use a new sharp drill, that will help a lot. will drill through it like butter.
    Personally I woudlnt get the Vast eliminators, 50 bucks is expensive for wht you get. Go to Autozone and get spark plug eliminators, as I have in the DIY post. (even have part numbers for what you need listed) total price under 10 bucks.
    I have no CEL with these, work great
    Hope that helps.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Quote Originally Posted by gointoscott View Post
    Hope that helps.
    Did you weld/relocate any sensors?
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Nope, I just the defoulers in the cats, and screwed the 02's into the defoulers. There are pic's in the diy.
    Jun 07 2007
    Ontario, Canada
    Thanks all for your feedback.
    I'll check the DIY writeup.
    Does anyone know about the CEL eliminators, can i use them in where the existing O2 sensors are or will i need to have new O2 bungs located at a different spot and if so where is that?
    Will my car still pass the emissions tests after the pipes are piggied?
    Thanks again
    SS
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by S4Steve View Post
    Thanks again
    SS
    Just use spark plug non foulers from the DIY above. As long as you pass readiness in VAG-COM, you won't have a problem passing emissions.
    08 S4- Stock SOLD
    Jun 07 2007
    Ontario, Canada
    Wow fast responce, kewl
    I already have the CEL Eliminators from VAST
    They were 50 bucks, oh well , i have them now...
    Am i to use just these in line with the O2 sensors and if so what ones the sensors on the pre cats(piggies) or on the sensors that are on the cats???
    SS
    Jan 29 2007
    08 S4 00 S4
    MD
    Screw them into the secondary(rear) O2 bungs, the ones down by the main cats, then screw the O2 sensors into them.
    08 S4- Stock SOLD
    Good luck on that new drill going through it like butter part lol
    Take what you estimate time wise to get it drill and double it at least. I'm a fast worker but those cats are a bitch and then some
    Jun 07 2007
    Ontario, Canada
    Thanks a bunch!!!!!
    Now to get my ducks in order and start this job.
    Here piggy piggy...
    SS
    Aug 06 2008
    Canadia
    how much faster does it make the S4 based on the butt-dyno?
    I'm probably going to be replacing my turbos in December, i'm thinking of doing piggies at the same time...
    Jun 07 2007
    Ontario, Canada
    good question
    i think it just lets your turbos work a bit easier
    ss
    Jun 28 2008
    Savannah, GA
    yeah, you will really hear the turbos spool up more once they are done, can I really feel it, maybe some but I did mine at the same time as cat back so, it was more of a difference.
    2000 s4
    Jun 24 2008
    Quote Originally Posted by readimag View Post
    Just a friendly reminder, that getting a mask is probably the most important part of the whole process. The dust that is produced from the cats is highly carcinogenic. Please wear masks when you do piggies, guys.
    *Edit* Oh, and the piggies should provide more power. It won't be as much as getting a chip or anything, but the turbos will spool faster, and the exhaust will flow easier, so I wouldn't be surprised if you gained around 30 horsepower.
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    i took mine to cherokee muffler in stockton and 40 bucks later and 4 days....still not done.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Cbowerman View Post
    I would've walked away from a shop that quoted me 40 dollars to do downpipes? That's nutty...Why did you pay them before the work was done?
    08 S4- Stock SOLD
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    It is a little bit of work gutting the precats, but they are not that hard. I used a drill, prybar, screwdriver and hammer. Oh I also bought a 15 dollar vice and clamped the precats in the vice, that really helped while your banging on the thing. The one that has a straighter line to the cone took a little over an hour. The other one took about 2 hours. Done.
    May 26 2008
    Riverside, CA
    WOW!!! 3 hours to gut them?? I have not done mine yet but was was expectting no more then half that.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Caddy7 View Post
    Once you get the technique down, you can do it in about half that time. First time, it's likely gonna take you that long if not longer.
    08 S4- Stock SOLD
    May 26 2008
    Riverside, CA
    Ok, how big drill are you recommending? I was thinking trying 1/2" regular drill and maybe one of those 1" "hole saws"
    Jan 29 2007
    08 S4 00 S4
    MD
    Yup, those are a couple of the many tools I use. Make sure it's a quality drill with enough torque so that it doesn't bog down in the cat material. You'll know what I mean the first time the drill tries to dislocate your elbow
    08 S4- Stock SOLD
    Jun 09 2008
    Lodi
    Quote Originally Posted by mholme View Post
    because they do all of the exhaust for our race cars. they are now done. i guess they ran out of oxygen for the torch.
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    good luck even getting ur DP's off ur car, unless you have a lift.....but on jackstands.....haha, yea its a job 4sho!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    fuckpiggies. that shit is a waste of time. i went ahead and bought 3 inch downpipes i got so frustrated with it.
    [the amount of work it takes to get them out and back in + drilling those cats out, you may as well end up with aftermarket dps]
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by 2fastS4 View Post
    It's really not that bad on jack stands. It also lets you work easily from the engine bay and underneath the car.
    08 S4- Stock SOLD
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Quote Originally Posted by ThirdStrike View Post
    That is if you want to go ahead and blow the grand for the aftermarket dp's. The extra 10 hp is not worth the grand+ for the pipes.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    May 26 2008
    Riverside, CA
    ^ +1
    Aug 06 2008
    Canadia
    i'd love set of ASP 3" DP, but theres no way i'm going to spend $1600 on that.
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    exactly. not worth it.
    Oct 31 2007
    Grand Rapids, MI
    Dude, please please please don't tell me u are one of those "guys" that is insitant on being able to do Piggies in "under 4 hours on jackstands"......cuz that is im-fuckin-possible, maybe not for WMS or ASP, but someone that has never worked on an Audi before, it is impossible (talking about me, not u).
    I duno, maybe u have experience w/ Audi's before, but if it was ur first time doing Piggies on jackstands either by yourself or w/ some1 else that has never done them, I cannot imagine them taking any LESS THAN 6 hours minimum
    Hell, it took me and my buddy 6 hours just to get the fuckin drivers side front O2 sensor off!!!
    MKIV BPM R32 (DD)
    Jan 29 2007
    08 S4 00 S4
    MD
    How you gathered that I am one of those "guys" from me saying it's not that bad on jack stands.... It took me two days to do the install, with about 4-5 of that gutting Coming out was much harder than putting them back in obviously. It's perfectly doable on jackstands in a garage or driveway, whatever you have.
    I've worked on Audi's for over ten years now and piggies are one of, if not the most involved DIY's I have ever done. The first time, yeah it's gonna take a while, but once you have gutted and installed them a couple of times, you learn what works.
    08 S4- Stock SOLD
    Oct 31 2007
    Grand Rapids, MI
    I was just assuming you were one that says how easy Piggies are to do, simply b/c I see alot of them on both here and AW and it frustrates me to know these people are telling guys like us this is an easy mod, when clearly, it isn't.
    Didn't mean to go off on you, I just hate it when someone says they did Piggies in their driveway on jackstands in 4 hours. It also took me the greater part of the weekend to do and was frusturating as hell!!!!
    I just try and warn others that have not done this before how large and involved of a task it is and to not go into it thinking it is as easy as unscrewing a certain number of bolts and voula!
    MKIV BPM R32 (DD)
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by OldYella View Post
    i always seem to negate the fact that i didnt buy a single part for my stage 3 setup (w/the exception of turbos) new. all my shit sourced from you guys at discounted prices
    Jun 07 2007
    Ontario, Canada
    Baddum baddumm
    ss
    Jun 07 2007
    Ontario, Canada
    Not cuttin to make piggys, i'm going to drill them out...
    How long drill bit would one use and what diameter....
    Any other tools or tricks
    We will use good dust masks (thank 4 the tip on that, GS)
    S
