Results 1 to 9 of 9
Thread: Need help
    Established Member Two Rings 02QuattroA4's Avatar
    Sep 29 2008
    2002 Audi A4 1.8T Quattro
    Southern California
    Need help
    Im looking for someone that knows what they are doing on audis. i was wondering if someone here would be able to install a dv on my 02 audi a4 1.8t quattro. i just want that pppssssshhh sound when i shift. i would need someone to get the part and install it. and charge me for the part and labor. im located in whittier but im willing to drive. thanks in advance.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Re: Need help
    Are you really that uncomfortable with doing it yourself?
    It's a pretty simple mod. There's a DIY on here. I'm not the most mechanically inclined person myself but doing work yourself is what makes it so fun!
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Re: Need help
    Quote Originally Posted by 02QuattroA4 View Post
    a DV won't get you that sound... you need to rip the whole airbox out and slap on a new intake or cone filter, or get a BOV.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Jun 29 2008
    Re: Need help
    You can get that sound with the Forge 007 or Forge SPLIT-R. But he's right, you'll need an intake to hear it really well.
    -Damon-
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    Re: Need help
    mike @ canyon racer can do that for you in no time
    www.canyonracermotorsports.com all the info on his site hes located off the 5 in mission viejo
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Re: Need help
    i have a spacer that can make that sound. pm me.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Sep 29 2008
    Southern California
    Re: Need help
    well i swapped out the stock panel filter with a kn panel filter. does that help.
    Veteran Member Three Rings midn12ght's Avatar
    Jun 17 2004
    socal
    Re: Need help
    it seems like you're doing everything to get around replacing the dv on making that blowoff sound. the only aftermarket dv i've seen that'll even come close is a go fast bits model. the stealth you can turn on/off - believe me that noise will get on your nerves after a while.
    i have a k&n, and not much noise has changed. i will say after having a boosted intake you get a nasty growl when you blip the throttle. a good ineffective mod that makes noise...
    if you're uncomfortable, i'd go with fusion's response and talk to mike kondo. very good guy. or see if charlie[audiskatesnow] will help you out. he's a local enthusiast willing to help any of us out.
    You mustn't be afraid to dream a little bigger darling...
    Sep 29 2008
    Southern California
    Re: Need help
    thanks for all the help.
