how long has it been over boosting? Since you had the car?
What everyone is saying is true.
1. Buy the cheap ebay ODB-II cable. that is what I did. I think they are under 20 bucks shipped. on ebay. Then pm me for the older version 3 vag-com software and I can email it to you and you can check for codes and at least know exactly what codes you have and will know what to fix. This is a must to have to save tons of cash and not have to take it to the dealer or shop to find out what codes you have.
2. I know you want to do it right for the AWE boost gauge, but 250 bucks is highway robbery. You can get a cheap glowshift gauge for 35 maybe 40 bucks tops, and will work great. A boost gauge is a must. yes the awe's look better, but to have a temp gauge for 35 bucks isnt really throwing money away, you could always sell it later when you want to get the right one, and recoop most your money back and only be out 10-15 bucks total. Well worth knowing what your boost is.
Back to your overboosting issue. Yes the N75 is what controls boost, I personally doubt its the waste gate. does the car have a MBC on it? It will be hooked up close to where the n75 is. If you do have a mbc, see if it is hooked up by itself (standalone) it might be a little tricky to notice because most times people will leave their n75 electrical connection hookedup, and just have 2 of the hoses disconnected and hooked up to the mbc. if you are running mbc standalone -this could be your cause of overboosting, at least that is why my car was overboosting.
If you do not have mbc, then it could be n75, they do go bad.
I disconnected my n75 for a short period of time and ran mbc in stand alone and i would get codes for overboosting and it would cut out like what you have happening, basically run in limp mode.
One last thing, if you have a bad egt it will also cause your car to go to limp mode, where it wont boost and be sluggish. that can be intermittent where at one time when you punch it it boosts, then other times it will be doggy. Plus it doesnt always throw a CEL light. But it will show up as a code if you vag it.
Anyway I ended up hooking my n75 back up and now run it parallel with mbc and now its running perfect.
